Jesel Dogbone conversion Dove-A block
Has anyone done a Jesel dogbone conversion on one of these blocks? Maybe have some pics you could share. I realize I will need to get the Jesel fixture to machine for the hold down.
I was wondering if the hold down stud is on the lifter bore centerline, since the block is sloped in between the lifter bores if the stud is on the lifter bore centerline the spot face for the spacer would need to be fairly deep it seems.
I have a really nice set of .904 dogbone lifters and I would like to Bush the bores and use them on this project. I am a machine shop so I can do that in house. Thanks
stuska1- Posts : 12
Re: Jesel Dogbone conversion Dove-A block
get the dogbone/stud kit from Jesel . . . self explains from there
lifter bore center to center have to be dead on for the pair
DanH- Posts : 1081
Thanks I talked to Jesel Today. Cleared some stuff up for me.
stuska1- Posts : 12
So how did this work out for you? Just wondering.
Thanks.
Thanks.
windsor- Posts : 1167
» .937 Jesel Dogbone Lifters with .850 Rollers (Push rod cups centered)
» DOVE block
» 4 bolt conversion on a D9 block
» DOVE block
» DOVE A block
» DOVE block
» DOVE block
» DOVE A block
