Which tire would be faster ?
Which tire whould be faster on say a 400 to 650 N/A HP at the wheels with good suspension thru a A/T trans and 4.11 gears ?
http://www.mickeythompsontires.com/strip.php?item=ETStreetRadial
OR
OR THESE
http://www.mickeythompsontires.com/strip.php?item=ETDrag
Also would you see a et difference between the Three ?
OR
OR THESE
whitefield- Posts : 2244
Re: Which tire would be faster ?
if its a track car go with the slick. what size are you needing?
richter69 wrote:if its a track car go with the slick. what size are you needing?
28/11.50/15 or 275/60/15 on a 10" wide rim.
Call Carl Robinson at Mickey Thompson and he'll tell you what you should do.
Tell him NICKEL sent You
Ace
Ace
powerstrokeace- Posts : 1496
if its a track only deal put a mt 28 x 10.5S on it and be done...................they work
powerstrokeace wrote:Call Carl Robinson at Mickey Thompson and he'll tell you what you should do.
Ace
I talked to him and and we figured the ET street would work good for the BBF Failane and The drag radial for the sbf mustang.!
Who knows I may swap around and see which is faster and may try the slicks too!
Sounds like your going to answer your own question..............
IDT-572 wrote:Sounds like your going to answer your own question..............
Sounds like I did,but won't know for sure until spring !
» tire size back half frame kits tire width on 70 mustang
» DOG vs GUN! what's FASTER?
» What do I need to do to get this thing to run 10.0's? Sorry long post.
» Another gas vs alky test..................
» Getting faster
» Getting faster
