Vale Springs
Mark Laczo
bosshoss
Vale Springs Empty Vale Springs
Post  69F100 November 11th 2012, 4:17 pm
I am going to be running solid roller cam in the .720 rang just wondering what valve spring most people perfer.I have A429 heads right now they have the comp cam
Valve Springs... 930-16
Ti retainers 732-16
Valve locks 611-16
Lash caps 621-16
Vale Springs Empty Re: Vale Springs
Post  bosshoss November 11th 2012, 4:53 pm
I have had good luck with the K Motion springs. Dont know about the Comp stuff.
dkp
bosshoss
bosshoss
Vale Springs Empty springs
Post  Mark Laczo November 11th 2012, 5:23 pm
Those 930-16 spring are a dual spring that have about a 153lbs seat and 383lbs open.
Which look like they are for good hydraulic or flat tappit cam.
If it is a solid roller you will need something better in a double spring but not necessarily a triple.
Your cam card should have a recommended spring spec whether a part number or a seat pressure & open pressure as well as spring heights.
One of the head guru's will be able to be more specific but you also need to be more specific on the actual cam specs if you have them.
FWIW Mark
Mark Laczo
Mark Laczo
Post  69F100 November 11th 2012, 5:40 pm
Mark Laczo wrote:Those 930-16 spring are a dual spring that have about a 153lbs seat and 383lbs open.
FWIW Mark
I know my springs want work that the reason I was wondering what most people perfer on springs the cam spec don't know them yet don't have the cam yet.Just wanting to see what brand most run
Post  Mark Laczo November 11th 2012, 6:09 pm
Oh sorry I see.
I have ran the Crane doubles(99893), Comp triples(947)
& yet to be ran Manley Nextec's doubles (blue stripe & green stripe).
I hear the K Motion & PSI are also very good.
Mark
Mark Laczo
Mark Laczo
Post  dfree383 November 11th 2012, 7:14 pm
Run what the Cam Grinder Suggests for your application.
Post  cool40 November 11th 2012, 8:18 pm
manley has worked good for me.i have pac on the new bullet. Smile
Post  rmcomprandy November 11th 2012, 8:48 pm
69F100 wrote:I am going to be running solid roller cam in the .720 rang just wondering what valve spring most people perfer.I have A429 heads right now they have the comp cam
Ti retainers 732-16
Valve locks 611-16
Lash caps 621-16
What valve spring installed height do you have...?
Post  69F100 November 11th 2012, 9:33 pm
Not sure they are on the truck right now I need to pull them and check everything.The heads was already setup when I bought them and put them on with the comp 930-16
Post  c.evans November 12th 2012, 12:04 am
Most likely your heads are set up for a 1.900 or 1.950" installed height. However, you will need to absolutely check them and find out for sure. I understand what Randy is saying, and you really need to do that before this discussion goes any further.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  2fox November 12th 2012, 12:23 am
Cam motion is in my home town.they done couple of customs came for me all solid roller
I did have a problem with K800 springs I think? It was on a 362w in a daily driver 83F100 truck I had two broken springs 1 innner broken and the outer one gave me the miss I was feeling. Not that many miles 4K if that. I went to cam motion to get 2 new springs they. Said to replace them all which I did. Bit they where comp cam springs they sold me no problems to date. Personally I wouldn't run cam motion springs again.
Last edited by 2fox on November 12th 2012, 12:24 am; edited 1 time in total (Reason for editing : spell check mishap)
2fox
Post  69F100 November 12th 2012, 3:00 am
Thanks Guys I will post the installed hieght when I pull the heads off just trying to see what brand most like .I am just trying to get all my ducks in a row before I start building this will be my 1st stroker engine.It might take me 2 or 3 more months on this build but I want it right when I hit the track with it so they will be a few more question I will be asking.
Post  rmcomprandy November 12th 2012, 11:32 am
69F100 wrote:Thanks Guys I will post the installed hieght when I pull the heads off just trying to see what brand most like .I am just trying to get all my ducks in a row before I start building this will be my 1st stroker engine.It might take me 2 or 3 more months on this build but I want it right when I hit the track with it so they will be a few more question I will be asking.
Just about ALL brands are wound by the same original people with maybe different finishing techniques.
Each brand has both excellent, good and not so good springs in their offerings so, it is the INDIVIDUAL spring which will fit that application correctly which is most important.
Post  BOSS 429 November 18th 2012, 12:33 am
Get it fig out ok?
Post  69F100 November 18th 2012, 8:42 am
BOSS 429 wrote:Get it fig out ok?
Not yet working long hours at work hadn't had time to touch it yet maybe during thankgiving I can get the installed hieght
