Residual Brake vale
Residual Brake vale
I was wondering if adding a residual brake valve to back drum brakes will help with a spongy pedal?
I have willwood front disc brakes and Wilwood master cyl and the pedal seems a little spongy,
Would this help?
Tore
Would this help?
Tore
Tore- Posts : 865
Re: Residual Brake vale
Aftermarket residual brake valves usually help if the brake fluid is draining back from the calipers/wheel cylinders to the master cylinder (if say the m/c is mounted lower than the calipers or wheel cylinders). If used the aftermarket residual brake valves are usually 2lb (disk brakes) or 10lb (drum brakes).
Any chance there is still air in the system? Or the wrong size m/c? Or the wrong brake pedal ratio? Or m/c plumbed "backwards" (IE back brakes applying first before front brakes do)?
DILLIGASDAVE- Posts : 2262
Wildwood says that its needed for the back drum brakes and it will help pedal travel. Just wondered if anyone here has been in tune with a situation like that.
Tore
Tore
Tore- Posts : 865
Tore wrote:Wildwood says that its needed for the back drum brakes and it will help pedal travel. Just wondered if anyone here has been in tune with a situation like that.
Tore
I have never used an aftermarket master cylinder with drum brakes so I can't really say either way. I guess you could always try a 10 pound valve and see what happens.
Residual valve
Tore I have that wilwood master cylinder as well on my 67 comet I installed the recommended 10 lb. residual pressure valve I have the best pedal I have ever had . Several of my buddies said you don't need it .Well I installed it and it worked for me .I little plumbing is required and lots of bleeding but it was worth it to me .
manofmerc- BBF CONTRIBUTOR
» DILLIGAS Dave...Residual valve ???
» Trans Brake vs Foot Brake
» Vale Springs
» D.O.V.E. vale lengths
» 521 cid broken camshaft dowel for timing gear . bent valves
» Vale Springs
