Best flowing standard BBF exhaust port
Alvin
Best flowing standard BBF exhaust port Empty Best flowing standard BBF exhaust port
Post  Alvin November 16th 2012, 9:08 pm
Which is the best flowing standard height Big block Ford exhaust port?
Alvin
Best flowing standard BBF exhaust port Empty Re: Best flowing standard BBF exhaust port
Post  schmitty November 16th 2012, 9:19 pm
Why are you worrying about the exhaust flow? Suspect
Post  rmcomprandy November 16th 2012, 9:25 pm
Alvin wrote:Which is the best flowing standard height Big block Ford exhaust port?
At OEM height ... Probably the P-51 head.
Post  Alvin November 16th 2012, 9:44 pm
Not worried, just curious. I just finished a Blue Thunder standard Ford port, and wondered what to expect.
Alvin
Post  BOSS 429 November 18th 2012, 12:29 am
BT is a good head
Post  cool40 November 18th 2012, 12:59 am
will the BT "BBC" out flow the BBF?
Post  BOSS 429 November 18th 2012, 1:10 am
I have 1 of each here, bbc bolt pattern,and a bbf one, we flowd the bbc a few weeks ago,and when I get time we will do the bbf port in a few weeks
Post  c.evans November 18th 2012, 1:47 am
Alvin wrote:Not worried, just curious. I just finished a Blue Thunder standard Ford port, and wondered what to expect.
If you did a real good job, expect 250 cfm WITHOUT a test pipe.
Lee,
The Blue Thunder BBC bolt pattern exhaust will outflow the Ford bolt pattern exhaust by about 30 cfm. A good BT with the BBC pattern will flow 280 cfm WITHOUT a test pipe,,,,and a good BT with the Ford bolt pattern will flow around 250 cfm. Remember now, that BT has a total of three different exhaust ports available with their CJ heads. 1. Ford standard location, 2. Ford 5/8" raised port, and 3. BBC bolt pattern raised port.
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  cool40 November 18th 2012, 2:10 am
Lee,
Charlie Evans
thanks Charlie Very Happy i have a truck puller friend looking for more ex flow with a stock type head so this may work for him.
