compression ratio ???? 460
i have 1969 460 going to put sealed power flat tops 30 over in with c9ve-a heads with standard deck height does anyone know about what it will be i'm thinking around 11.1
74f100- Posts : 28
Re: compression ratio ???? 460
With Sealed Power flat tops, about 0.015" below an OEM early block deck is typical, clean up the heads during the rebuild, you'll be approximately 11.25:1.
thanks man
74f100- Posts : 28
got the machine work done took 00.8 off the heads engine guy said about 10.75.1 comp ratio
with the flat tops
with the flat tops
74f100- Posts : 28
I was going to say 11.5,but Paul is lots more experienced than me.
» Compression ratio?
» Compression ratio
» compression ratio....what gas to use?
» D3 compression ratio
» compression ratio ????
» Compression ratio
