Compression ratio?
Compression ratio?
Trying to get an idea of my compression ratio but I am having troubles.
the engine is from a '76 Thunderbird, D0VE heads that have been machined .050". I am having a hard time finding specs for the 8265PT1 head gaskets though... Also, I know I can't get an exact number since I don't know exactly how far down my pistons are, or the exact CC of my combustion chambers etc...
using this quote
D3VEs compression is roughly 8:1, raise that to 9.5:1 by putting the D0VEs on then another 10cc less chamber via the .040 shave and I am guessing right around 10.2:1...?
using this quote
and the fact that D0VEs have a 76cc~ chamber, .100" more chamber created about a 21cc difference. So, .040 should make roughly a 10cc difference. Therefore, I would guess my machined heads to have around 66 CC chambers. switching from D3VEs to D0VEs will raise the compression about 1.5 points I am told. So, that would be about .07 points per CC of chamber."The 97cc volume of the D3VE comes simply by dropping the chamber about .100" deeper into the cylinder head casting"
SLOWnSTEADY- Posts : 53
Re: Compression ratio?
9.5-10:1 is pretty close
» compression ratio ???? 460
» Budget 466 build, hp guesstimate.
» Compression ratio
» compression ratio....what gas to use?
» D3 compression ratio
» Compression ratio
