Converting a 4150 intake to a 4500
Converting a 4150 intake to a 4500 Empty Converting a 4150 intake to a 4500
Post  BigBlockRanger November 19th 2012, 10:20 am
Modified the intake on Saturday to accept a 4500. Did it in my driveway so I thought I'd throw it up here to show how easy it is.
4500 gasket on the 4150 flange.
Converting a 4150 intake to a 4500 486202_10151244245104485_1040868097_n
Sharpie'd an outline around the gasket.
Converting a 4150 intake to a 4500 63835_10151244245299485_433905673_n
Drilled holes along the lines I wanted to cut and took a ball peen and tapped the big chunks out. The casting is really thin where the clovers are because this intake is available in both flanges. If I were doing it again, I'd drill smaller holes along the perimeter so I would have less material to remove with the carbide.
Converting a 4150 intake to a 4500 178919_10151244245714485_1754667938_n
I countersunk the alumimum screws, then drilled and tapped the new stud holes. The new holes actually go through the heads of the filler screws.
Converting a 4150 intake to a 4500 74786_10151244246189485_32767848_n
Finished. I also drilled and tapped a vacuum port in the back because this manifold did not have a vacuum port.
Converting a 4150 intake to a 4500 579216_10151244246864485_1498888554_n
Converting a 4150 intake to a 4500 532344_10151246621649485_1231885434_n
Intake gaskets will be here today and I maybe I can find some time soon to button it all back up.
Last edited by BigBlockRanger on November 19th 2012, 3:26 pm; edited 1 time in total
Converting a 4150 intake to a 4500 Empty Re: Converting a 4150 intake to a 4500
Post  rmcomprandy November 19th 2012, 11:45 am
If you intend to ever use any "plate" nitrous system then remove the front and rear sections of the "cloverleaf" so, it is straight across in the front and rear.
Post  BigBlockRanger November 19th 2012, 2:27 pm
Thanks for the tip!
Post  jbozzelle November 21st 2012, 1:20 pm
Easy enough!
Any special tools? Drill press?
Post  BigBlockRanger November 21st 2012, 2:25 pm
Nope. I used a block of steel with a hole drilled in it as a dill guide and drilled it with my 1/2" hand drill. Drilled, tapped, done.
Post  Mike R November 22nd 2012, 12:39 am
Nice job. Thanks for posting the pics, it's going to make it easier for me when I do mine.
Post  alkymark8 November 23rd 2012, 7:57 pm
Thanks! I am going the other way with my intake. Where did you get the alum screws???
alkymark8
Post  BigBlockRanger November 24th 2012, 8:47 pm
I ordered them from Mcmaster Carr.
