Head repair problem
Head repair problem
This head has had a hole in the deck surface repaired. When the hole was fixed the water jacket was welded shut. Will it be ok or should a hole be drilled there? The head has not been ran since the repair.
There should be a hole here.
daveboys- Posts : 11
Re: Head repair problem
It will be okay to run it as is, IF, If, if, that head will be used as drivers side, cyl. #5 for the rest of it's life.
If that head is ever going to be run on passenger side, as cyl. #4, then you will want/need to drill it out.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
thanks charlie - That head is about used up......In fact 10 years ago I thought it was beyond repair, but I found some on to save it and he did a fanastic job repairing the hole in the deck surface. I think I will just run it on the drivers side to not risk damage to the repair.
Well, you are probably just looking at the two heads and comparing them. More importantly, you should "correctly" lay a head gasket on the head and look at the water openings in the head gasket.
Essentially at the front of the head gasket you have small steam holes and then at the rear of the head gasket the holes become larger in order to actually pass some hot water.
Charlie
Charlie
When laying a felpro 1018 on the head there is a small hole where the hole in the head use to be. The hole in the lower right of this picture. Thank for the help. I glad to know I don't need to drill it.
Well you can drill it if you want to. I probably would. But my point is, that it does not need to be a big triangular hole like what the heads were cast with. It only needs to be a 1/8" diameter steam hole and directly in line with the hole in the head gasket.
Charlie
Charlie
