Eagle broke crank
+9
QtrWarrior
kim
ED502
dtimmer
soupbean
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Eagle broke crank
Wheelie58 wrote:bLem Evans wrote:Lem Evans wrote:Remove the rod and see if it broke at the fillet radius.
enough of the ......
1] dampner
2] low battery
3] hydraulic
Did it break at the fillet radius?
Lem,
Is that like the filet that the Texas Roadhouse has?
I got filled on one of those, but my crank was ok.
Having any fun in Ga. ?
Lem Evans wrote:Wheelie58 wrote:bLem Evans wrote:Lem Evans wrote:Remove the rod and see if it broke at the fillet radius.
1] dampner
2] low battery
3] hydraulic
Lem,
Lem....it is always fun in Georgia...
Just ask Soup....
I just took my truck to the store and fillet up with diesel...........
I reckon that would be fillet radius mignon... but why?
soupbean- Posts : 637
Gotta love the CDB.Wheelie58 wrote:Atlanta....via Livermore....like the Uneasy Rider
schmitty- Posts : 4538
Not enough material in the forging in that area..
That hole in the rod journal is just too **** big !!!
QtrWarrior- Posts : 2702
What's the bearings look like?
Lem Evans wrote:Getting back to the broken crankshaft issue.........I've seen Bryant crankshafts break in the same place. The common themes are that the journals were turned .010" under. My first though was about the lose of surfice heat treatment. After talking to informed crankshaft professionals.....best answers were...local grinder srewed the radius up.
If soup's crankshaft broke at the radius:
1] Poorly done radius.
2] Flexing in that area.
3] Both.
What would cause flexing?
dfree383 wrote:What's the bearings look like?
Not bad. A little wear but that could have come from after the breakage.
soupbean wrote:dfree383 wrote:What's the bearings look like?
But I'm no expert either. A few visible scratches and some dark spots but nothing that you can feel.
soupbean wrote:Lem Evans wrote:Getting back to the broken crankshaft issue.........I've seen Bryant crankshafts break in the same place. The common themes are that the journals were turned .010" under. My first though was about the lose of surfice heat treatment. After talking to informed crankshaft professionals.....best answers were...local grinder srewed the radius up.
3] Both.
Not enough steel in the right place. Like mike said, the lightening hole in the throw could be too big. The radius could be too small or 'weird' in some way.
Page 2 of 2 • 1, 2
» 4.3 eagle crank
» Shorten Eagle crank snout
» 4340 eagle crank
» Eagle crank for sale
» Eagle 4340 crank
» 4340 eagle crank
» Eagle 4340 crank
Page 2 of 2
