Electric vs Engine Driven Fan
mtacqua
crittersf1
This is something I have been back and forth on since I started planning the Econoline project. What's the consensus on them. I like the simplicity of an engine driven fan and not being concerned about electric motors, relays, sensors failing. But on the other hand a well design electric system, at highway speeds the fan may never turn on. What's your opinion
Re: Electric vs Engine Driven Fan
coupled with an electric pump and you can cool the car with the motor not running. Also, when the it's cold out I leave the fan off.
mtacqua- Posts : 67
A good clutch fan is hard to beat.
One thing I forgot to mention for those that don't know, this is not for racing. It's a highway vehicle for towing only.
I'm not sure in your case what would be the best but I have put over 300,000 miles on 2 1996 Taurus's with no problems with the electric fans and I believe that all newer vehicles use electric fans and they can't all be wrong! I think that it would be easy to use the electric fan with a temp switch and a manual by-pass switch just in case. Just my 2 cents.
jeffgfg- Posts : 338
i had a dual flex-a-lite setup on my lightning and it worked great.it was a variable speed deal so it never run hard unless the air was on in town on 100*day.
For what you are doing I really do agree w/Dave and the clutch fan.
» fuel pump 600 hp give or take .. best bang for the buck
» daily driven big block
» Going to the races
» Cooling System - STREET DRIVEN
» Belt Driven Oil Pump (Non dry sump)
