Timing chain catastrophe.
norm
70FB
fordguy69
Well, out playing with the Mustang today, the timing chain broke at about 5000 rpm.
This is a stock bottom 72 460 with factory dish pistons, C8VE heads, with slightly larger than stock valves. Also using a very small Edelbrock Performer hydraulic cam, something like .480 lift and 200 duration at .050.
What are the odds that I DIDN'T bend valves? I am hoping that with this little cam and dished pistons, maybe they didn't kiss? Am I just dreaming?
fordguy69- Posts : 98
Re: Timing chain catastrophe.
I don't know but I had one turn loose at 5000 in a stock 70 302 with a stock cam and it bent 2 intake valves. It had the original chain in it. I have never touched another engine without replacing the chain with a quality one.
70FB- BBF CONTRIBUTOR
I would say about as good as winning the lotto.
norm- Posts : 261
Most likely have some valve/pushrod damage, but getting to the root cause of the chain failure would be my #1 priority.
Was this a fresh engine or does it have some time on it?
maverick- BBF CONTRIBUTOR
It's got some time on it. It's an old engine I had lying around from another car and threw it together just to get all the bugs sorted out on the car before I put a good motor in it. Guess my timeline just got accelerated.
fordguy69 wrote:It's got some time on it. It's an old engine I had lying around from another car and threw it together just to get all the bugs sorted out on the car before I put a good motor in it. Guess my timeline just got accelerated.
If it was the factory chain the nylon top gear more than likely went bye bye
Wheelie58 wrote:Most likely have some valve/pushrod damage, but getting to the root cause of the chain failure would be my #1 priority.
X2
» Advance Cam or Not ?
» Timing chain and oil pan questions
» Timing chain help
» Timing chain stretch
» Timing chain
» Timing chain help
» Timing chain
