Looking for Aluminum block and 5.25" crank
Looking for 11.200", or 11.700" Preferred, deck wet block. A/R, C&C, or old Ford Motorsports. 4.900" bore space only, no 5.0 bore space. If it needs sleeves, or other work Ok. Pm me with block info and price.
Also, looking for 5.200" to 5.300" crank.
gordyd4- Posts : 145
Re: Looking for Aluminum block and 5.25" crank
gordyd4 wrote:Looking for 11.200", or 11.700" deck wet block. A/R, C&C, or old Ford Motorsports. 4.900" bore space only, no 5.0 bore space. If it needs sleeves, or other work Ok. Pm me with block info and price.
wow what you building ? and what is it going in ?
My last car had an all aluminum 604, and after I bought the C-heads I was regretting I did not get the Hemi heads.
I was kinda all over the board with what I was going to build now, and decided this motor is gonna be 700 CID Hemi. Not sure what I'm gonna put it in. Was thinking about building a 67 Shelby from TM race cars, but I keep coming back to a 69 Mustang because it would have some nostalgic flavor with the big Boss engine.
Winberg may have a crank in stock. Of course it will be a new billet. When I talked to them yesterday they said they had a few 5" plus cranks in the works.
Bret
Bret
Bret Powell- Posts : 133
I'm looking for used or a new one that someone bought that I can buy for used price.
gordyd4 wrote:I'm looking for used or a new one that someone bought that I can buy for used price.
I'd be real suspicious of a used one, the overlap of journals on these cranks is negligable, and therefore the cranks tend to have cracks appear between the journals in the counter weights. As far as finding a new one for used price, that might be possible, but not probable. You probably should just buy new and know what you have for sure. Sounds like a heck of a beast if you get it together.
schmitty- Posts : 4538
schmitty wrote:gordyd4 wrote:I'm looking for used or a new one that someone bought that I can buy for used price.
You make a good point; I'm not in a hurry for parts, so maybe something will surface that's worth buying. I would surely have a used crank checked out.
That's big time.cash there. Great.build.
2fox- Posts : 275
Parts found,
Thanks, Gordon
Thanks, Gordon
» running 4.75 crank in aluminum block
» aluminum crank pulley and a crank trigger
» If you swap from iron block to aluminum block,,,
» anyone looking for a aluminum block
» Gonna be looking for aluminum block.
