running 4.75 crank in aluminum block
running 4.75 crank in aluminum block Empty running 4.75 crank in aluminum block
Post  hbstang September 23rd 2019, 4:33 pm
i have an option to use a 4.750 crank im my c anc motorsorts block.it has a bore of 4.625,would this put to much load on cylinder walls/ rings ? N/A engine build with a-441 heads.standard 10.320 deck block.
also how would e-85 do at 14 to 1 comp on this?
running 4.75 crank in aluminum block Empty Re: running 4.75 crank in aluminum block
Post  JBR-3 September 23rd 2019, 7:45 pm
Last edited by JBR-3 on October 17th 2020, 3:13 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Post  gt350hr September 24th 2019, 1:49 pm
Dan with a 6.7 rod it makes a 1.225 C/H and that is still OK. Cylinder wall loading is subject to skirt profile and length plus top ring land diameter. I think E85 would be OK with the aluminum head @ 14-1. You know i'm only a mile away.
gt350hr
Post  JBR-3 September 24th 2019, 6:03 pm
Last edited by JBR-3 on October 17th 2020, 3:14 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Post  BOSS 429 September 24th 2019, 9:31 pm
In on 1
