What do I need to do to get this thing to run 10.0's? Sorry long post.
+17
sixtynineford
fastford600
DJOHAGIN
torkair
4thHorseman
342g
bosshoss
512Fairlane
21 posters
Page 3 of 3 Previous  1, 2, 3
What do I need to do to get this thing to run 10.0's? Sorry long post. - Page 3 Empty Re: What do I need to do to get this thing to run 10.0's? Sorry long post.
Post  windsor March 6th 2010, 11:03 am
cheers
Post  '65 T-BOLT March 6th 2010, 1:01 pm
excellent! the new convertor should help alot. My car also weighs 3500 lbs.best i went with a 521/c4 combo 3500 convertor,went 10.64 spinning at 122 mph first pass no tuning.(had bearing failure) It was a Ford 521 crate engine,647 cam,BT intake pair of 660's. I changed cam..thanks Lem, Victor and a domi for this year.
'65 T-BOLT
'65 T-BOLT
What do I need to do to get this thing to run 10.0's? Sorry long post. - Page 3 Empty Cool.
Post  512Fairlane March 7th 2010, 3:51 pm
Sounds like a similar combo to mine. Are you bringing it to the Bash?
512Fairlane
512Fairlane
Post  '65 T-BOLT March 7th 2010, 11:10 pm
if you are asking me! Nope! The car is still apart, need valves and retainers from Lem...I need Money to do this. I do want to come and spectate! Maybe next year if and when I move to KY...For now I have to dream
'65 T-BOLT
'65 T-BOLT
Post  '65 T-BOLT March 7th 2010, 11:13 pm
My ride has Fox body coil over struts, caster camber plates, Aerospace brakes and a rack. Is your 64 stock front suspension?
'65 T-BOLT
'65 T-BOLT
Post  512Fairlane March 7th 2010, 11:43 pm
'65 T-BOLT wrote:My ride has Fox body coil over struts, caster camber plates, Aerospace brakes and a rack. Is your 64 stock front suspension?
Mine has some a-arms off of an original Thunderbolt that were stored in my dads garage attic since the 60's. We lowered the upper a-arm mounting point about 1 1/2" to help out the geometry and installed Granada spindles and brakes. Otherwise its pretty much stock up front. We have been considering doing exactly what you did with fox struts because most of the header clearance issues are around the upper a-arms and steering box. I also have issues with the upper a-arms sliding in from wheelies. Did you keep your shock towers and mount the struts to them or cut them all the way out? I'd love to see some pics if you have them.
512Fairlane
512Fairlane
Post  '65 T-BOLT March 7th 2010, 11:57 pm
I will take some picture tomorrow. I have the Crites shock tower kit installed, which means I kept the towers. I welded in a plate to fill the hole in where the shock passed through. Installed the CC plates, made some custom lowers,rack x-member,etc. I am moving the rack forward to where it was with the 428 windsor. my plans are to use an engine & mid plate this time around. My headers are Foxbody Hooker 2' swaps. I have about 15 hours in making them work.....I was really thinking about going with the Mustang 2 front but i am undecided!
'65 T-BOLT
'65 T-BOLT
Post  '65 T-BOLT March 8th 2010, 12:00 am
I have another 65 hardtop that i am working on. Granada spindles and brakes. question... did you have to modify(cut) your strut rods? when I got to turn the wheel, The spindle hits the factory stop on the strut rods.
'65 T-BOLT
'65 T-BOLT
What do I need to do to get this thing to run 10.0's? Sorry long post. - Page 3 Empty Sounds good.
Post  512Fairlane March 8th 2010, 12:08 am
That is exactly what I was thinking of doing. We were thinking about keeping the stock lower a-arms and changing the ball joint to a screw in Mustang. I run a motor plate in the front and some plates bolted to the back of my heads that run down to the frame as a mid plate. I'd like to run a rack but I think it will be a tight fit to clear the front sump pan. I've seen some people run a rack right in front of the pan under the balancer but it is really tight. Also, I think the rack might interfere with the strut rods. I was considering using some tubular Fox Mustang lowers but I'm not sure the mounting points would work with the stock frame rails. Luckily my Dad builds chassis and headers so we could really do whatever we can dream up I just don't really want to destroy the "stock" look of the car. With the shock towers its a bitch to work on and installing the headers takes a while but I like the Super Stock look of the car. Can't wait to see your pics. Thanks.
512Fairlane
512Fairlane
Post  512Fairlane March 8th 2010, 12:12 am
'65 T-BOLT wrote:I have another 65 hardtop that i am working on. Granada spindles and brakes. question... did you have to modify(cut) your strut rods? when I got to turn the wheel, The spindle hits the factory stop on the strut rods.
I didn't have to modify my strut rods. I never noticed them hitting anything. I'm assuming they didn't change anything in 65 but I'm not sure about that. My car actually started as a 63 but I think all of the suspension was the same as 64.
512Fairlane
512Fairlane
Post  '65 T-BOLT March 8th 2010, 12:40 am
we share the same front suspension parts. I can turn the wheels one direction but not the other. We made some brackets for the lower just like an aftermarket M2 front cross member, wide lowers to eliminate the strut rods. and yes. it was tight to the pan and balancer with the SBF. the BBf i used a Moroso Eliminator pan and moved the rack back...worked great till you go to back up, the wheels would toe in drastically. thats why i am moving it to the front again....you will see with my pics what i am talking about. I did the front conversion about 7 years ago, before FatMan Fabrication had their kit and they perfected it..but damn way to expensive and RRS just the same. I was thinking about using Foxbody lowers also, just need to change my lower mounts.
'65 T-BOLT
'65 T-BOLT
Post  '65 T-BOLT March 8th 2010, 11:44 pm
I have taken pictures today! My daughter was on the computer all night doing homework. I will post them tomorrow.
'65 T-BOLT
'65 T-BOLT
Post  512Fairlane March 12th 2010, 12:01 am
Any luck with the pics?
512Fairlane
512Fairlane
Post  '65 T-BOLT March 12th 2010, 5:37 pm
Do I need a photobucket account to upload photos?
'65 T-BOLT
'65 T-BOLT
Post  windsor March 12th 2010, 5:50 pm
nope
Post  '65 T-BOLT March 13th 2010, 9:19 am
I couldn't figure it out...computer illiterate!!!!! so i joined photobucket after doing a search on this site.
'65 T-BOLT
'65 T-BOLT
Post  '65 T-BOLT March 14th 2010, 9:45 pm
512 you have e-mail it should be 13 pictures with some descriptions.
'65 T-BOLT
'65 T-BOLT
What do I need to do to get this thing to run 10.0's? Sorry long post. - Page 3 Empty Thanks.
Post  512Fairlane March 14th 2010, 9:52 pm
Thanks a lot. I'll check them out.
512Fairlane
512Fairlane
