BBF FOX NEED INFO ON MANUAL MASTER CYLINDER.
+7
GTmustang
85bigblockfox
61coon
2fox
11 posters
Page 1 of 2
Page 1 of 2 • 1, 2
OK I.want to go manaul brake. What master cylinder is the easiest to do. Also do I need to modify the brake pedal Inside the car? Also I got 4.wheel disc.too thank.pics of your setup would be great.too thanks
2fox- Posts : 275
Re: BBF FOX NEED INFO ON MANUAL MASTER CYLINDER.
A mid 90's-late model dodge pickup truck master cylinder is a good swap. Aluminum housing and plastic reservoir.
61coon- Posts : 1824
Agreed. Dodge master cylinder. Drill a new hole in pedal. Use instructions from aerospace or strange for proper distance.
Or buy a manual swap kit from any racecar place that deals mustangs. Team z, skinny kid, etc...
whatbumper- Posts : 3024
I heard the skinny kid kit.wasn't.good.? The pedal.ratio? .whatbumper wrote:Agreed. Dodge master cylinder. Drill a new hole in pedal. Use instructions from aerospace or strange for proper distance.
on.my other fox I.had a.manual kit..didn't.mess.with the pedal.ratio ..but come.with rod thay was supposed to compensate for it.
With the.Dodge MC do I need.a alum plate.or.it.mounts to the org.booster.hoes. .and what about lines on the Dodge metric? Or.the same.size.lines. what model and year Dodge BTW thanks
2fox- Posts : 275
The strange kit looks like a dodge master cylinder anyway. Piss on that stuff. It puts your lines toward the inner strut tower area. I just use a upr aluminum plate with a 79 model manual brake master cylinder from a fox. Simple, easy, works great and under $100.
85bigblockfox- Posts : 241
X2, I always use the KISS theory (Keep It Simple Stupid!)! I picked up a manual brake pedal off of ebay, because it was simpler than modifying my old pedal.85bigblockfox wrote:The strange kit looks like a dodge master cylinder anyway. Piss on that stuff. It puts your lines toward the inner strut tower area. I just use a upr aluminum plate with a 79 model manual brake master cylinder from a fox. Simple, easy, works great and under $100.
Gary
GTmustang- BBF CONTRIBUTOR
2fox wrote:OK I.want to go manaul brake. What master cylinder is the easiest to do. Also do I need to modify the brake pedal Inside the car? Also I got 4.wheel disc.too thank.pics of your setup would be great.too thanks
M1931 from auto zone,or napa, about $20.00
have used about 30 of these works perfect, its alum,line come out toward fender
call me if you need more info
BOSS 429- Posts : 2372
changing the ped ratio is very inportant,and if you send it to me I ll weld it up and change it,or call me . I will tell you how to do it.
this master is off 83/84 ranger w/man brakes. have used it on 4700lb to 1800 lb cars 4w drums,from disc's,to 4 w disc's
theres one on my car now
BOSS 429 wrote:2fox wrote:OK I.want to go manaul brake. What master cylinder is the easiest to do. Also do I need to modify the brake pedal Inside the car? Also I got 4.wheel disc.too thank.pics of your setup would be great.too thanks
Good info
hey I was It was junk yard yesterday I seen a Dodge pickup 90 Morley had plastic tank alum cylinder. The lines.came.out to the fender side. Are the 2 fittings the same thread size? Or do I need to modify them thanks61coon wrote:A mid 90's-late model dodge pickup truck master cylinder is a good swap. Aluminum housing and plastic reservoir.
2fox- Posts : 275
BOSS 429 wrote:changing the ped ratio is very inportant,and if you send it to me I ll weld it up and change it,or call me . I will tell you how to do it.
Rich, is this the old square iron type?
I'm in need of a MC that is smaller than a Mopar type. Know of one? Are the aluminum ones on the Mustangs smaller?
jbozzelle- Posts : 3705
Just ordered the M1931 from Auto Zone 12.93.
jbozzelle wrote:BOSS 429 wrote:changing the ped ratio is very inportant,and if you send it to me I ll weld it up and change it,or call me . I will tell you how to do it.
Not sure why this didnt pop up and let me know there was a post till now?
NO its an alum unit,lines come out on left side toward drivers side fender, shorter then the mopar and not as long . same size as a stock fox body.Works great.
Good info....The valve covers on the Torino are too close to the master cylinder. If that MC is smaller and will work on a disc/drum combo I'll order one!
Dave C.- Posts : 1268
bigblok2000ranger wrote:Just ordered the M1931 from Auto Zone 12.93.
x2 ordered one today $12.93 plus what ever the core will be if it has a core charge.
I went by to pick it up and they said the supplier was out of stock on them and he didn't see when I ordered.Went by NAPA they tried to give me a iron one for that part number
Oh yeah haven't posted same thing happened to me ended going to Advance and picking one up for 18.99. It's a different part number I can get it for you tomorrow if you want. Atleast the guy at the Advance couunter had enough sense to notice that the other part number was discontinued.
bigblok2000ranger wrote:Oh yeah haven't posted same thing happened to me ended going to Advance and picking one up for 18.99. It's a different part number I can get it for you tomorrow if you want. Atleast the guy at the Advance couunter had enough sense to notice that the other part number was discontinued.
that would be great Eric
The Advance part number is 10-1931. It is aluminum but not the style with the plastic reservoir and comes with the pushrod. Core was $10.
bigblok2000ranger wrote:The Advance part number is 10-1931. It is aluminum but not the style with the plastic reservoir and comes with the pushrod. Core was $10.
Thanks Eric just ordered it be here at 4 pm
No problem Jim.
the agorementioned autozone special is aluminum and yes it is small.jbozzelle wrote:BOSS 429 wrote:changing the ped ratio is very inportant,and if you send it to me I ll weld it up and change it,or call me . I will tell you how to do it.
Barney wrote:the agorementioned autozone special is aluminum and yes it is small.jbozzelle wrote:BOSS 429 wrote:changing the ped ratio is very inportant,and if you send it to me I ll weld it up and change it,or call me . I will tell you how to do it.
What does it look like, I don't think I've ever seen an aluminum one that doesn't have a plastic reservoir. Pictures? Is this for disc/drum or disc/disc?
Gary
Looks just like the old style iron units but in aluminum.
Page 1 of 2 • 1, 2
» manual master cylinder for 2002 mustang
» SKRC: MANUAL MASTER CYLINDER CONV. KIT ~ 94-UP MUSTANG - BIG BLOCK
» Anybody mount the master cylinder inside the car?
» T-BIRD MASTER CYLINDER
» Need help with the brakes on my 72 mark 4 lincoln
Page 1 of 2
