manual master cylinder for 2002 mustang
manual master cylinder for 2002 mustang  Empty manual master cylinder for 2002 mustang
Post  frank13 September 19th 2010, 1:19 pm
ok pretty sure my master is making my front brakes not bleed of the pressure on the car.....locks up after like 5 pumps to a point i cant even move the car...had to drive 5 blocks with them on and fried a set of pads and caliper, replaced both caiper and pads....problem still there, so i am assuming it is the master since both brakes have the same problem at the same time....and i doubt both brake hose collasped at the same time .....
what is the best master from a local parts store like advance auto would be my best bet to pick up tonight.....
i dotn wanna redo the lines so a master with line towards the engine is prefered
either post or call me 4843189865
frank
frank13
frank13
http://www.frankskinkracing.com
manual master cylinder for 2002 mustang  Empty Re: manual master cylinder for 2002 mustang
Post  frank13 September 19th 2010, 1:44 pm
extra info you may need......
I have NO original hard line. everything is new except rubber hoses (2 years old)
No abs
using maximum motorsports pedal.
upr firewall adapter.
had a 93 cobra master on there
frank13
frank13
Post  frank13 September 19th 2010, 9:58 pm
figured out!
thanks bob!
frank13
frank13
Post  res0rli9 September 19th 2010, 10:00 pm
well what was/is it Question
Post  frank13 September 19th 2010, 10:06 pm
cant say till tomorrow
frank13
frank13
Post  frank13 September 30th 2010, 9:56 pm
problem still there....fixed the bent cclip that was holding the master pushed in almost 3/8 of a inch....thought that had to be the problem....
anyone have any ideas what may be causing the fronts to stay engaged, and not release.....
frank13
frank13
Post  jc10000rpm October 2nd 2010, 8:15 am
pump it up till there locked up again, crack the front brake line loose at the master, if wheels are still locked up you need to look down stream (proportioning valve), if it frees them up when you crack it replace the master cylinder.
btw , are you sure the pedal rod is not puttin pressure on the master, if you had it adjusted a hair too long could caus same problem
jc10000rpm
Post  jbozzelle October 2nd 2010, 12:01 pm
Make sure that rod is not pushing the MC still. You should be able to feel some play in the pedal if it is loose enough. Is the factory prop valve still on there? Did you ditch the ABS pump?
Post  TravisRice October 2nd 2010, 2:39 pm
Do you have a proportioning valve ?? Aftermarket or original?? Had a Wilwood go bad and do the exact same thing. Won't release until you crack the bleeder on one side.
Travis
