T-BIRD MASTER CYLINDER
Need to know what master cylinder to use when converting from power disc/drum to manual disc/drum on my 88 bird.
Thanks,
Steve
Thanks,
Steve
70429scj- Posts : 348
Re: T-BIRD MASTER CYLINDER
Hey, I figgered I would answer here.
They should be the same as the early Fox Mustangs. I think you can use the regular disk/drum master, the most important thing with the manual conversion is the push rod pivot point. It should be moved for better machanical advantage. The manual conversion kits show you where to mount it I believe.
I used a power booster from a Cobra Fox Mustang, it is small enough to fit with the BBF. I wish I would have went manual though.....
Bill
Bill
billandlori- Posts : 2081
how about this
AC-MBC7993 - Aerospace Components Mustang Manual Brake Kit
Aerospace Components #026-AC-MBC7993
1979-93 Mustang
$159.99 Ships Tomorrow
View In Catalog
Similar Items
Add to Wish List
Continue Shopping
Share |
Complete list of Aerospace Components Mustang Manual Brake Kit
If you are looking to convert from power assisted brakes to a manual system, this Aerospace Components kit has what it takes. It includes a billet aluminum firewall adapter (in place of power booster), new master cylinder and hardware. It will work with the OEM disc/drum system or aftermarket 4-wheel disc conversions.
Fits Applications:
1979-93 Mustang
View In Catalog
Similar Items
Add to Wish List
Continue Shopping
Share |
Fits Applications:
I'm using the Aerospace kit on my Mustang it worked good.You will have to go with a different style brake switch and modify the brake pedal but they give you directions.
Later Mark.
Later Mark.
Mark Miller- Posts : 1958
» BBF FOX NEED INFO ON MANUAL MASTER CYLINDER.
» Need help with the brakes on my 72 mark 4 lincoln
» Master cylinder/booster clearance
» manual master cylinder for 2002 mustang
» What stock master cylinder for a 69 Mustang???
