Master cylinder/booster clearance
Will I have clearance issues with SCJ heads, tall valve covers and master cylinder with brake booster im my ´69 Mustang?
Franz
Franz
Ashburner- Posts : 92
Re: Master cylinder/booster clearance
Between master cylinder/booster and valve cover..
I know the tall ford racing wont fit.i had some of the first ones made and it hit the m/c with the power booster.i cut and welded the first set but ended up pulling the booster off later.
So it wont fit at the stock position for sure?
Would be nice if you could write your experiences.. I don't know because the engine is stock right now, it will be worked on next winter..
Appreciate your support
» BBF FOX NEED INFO ON MANUAL MASTER CYLINDER.
» Brake Cylinder/Booster
» master cylinder
» Need help with the brakes on my 72 mark 4 lincoln
» T-BIRD MASTER CYLINDER
» master cylinder
