master cylinder
master cylinder Empty master cylinder
Post  muddog899 January 11th 2016, 1:35 pm
ok on my new build i need to change the master cylinder since i wont have any vacuum for the power brakes plus i will be running a 10.25 rear end out of my old truck that was coverted to disk brakes
new build is a 93 bronco with the dana 44 ifs front disk brakes rear will be the 10.25 with disk brakes will be used for sand drags.so what master should i look for to make sure everthing works good thanks for the help guys
muddog899
master cylinder Empty Re: master cylinder
Post  kjett January 11th 2016, 1:41 pm
muddog899 wrote:ok on my new build i need to change the master cylinder since i wont have any vacuum for the power brakes plus i will be running a 10.25 rear end out of my old truck that was coverted to disk brakes
I like my wildwood master cylinder. Just make sure the bore size is correct for your application.
kjett
kjett
Post  muddog899 January 11th 2016, 1:45 pm
how do i figure out the right bore size
muddog899
Post  kjett January 11th 2016, 1:47 pm
Give the folks at wilwood a call and tell them what you got and what you are doing. They will hook you right up on the correct master cylinder setup to fit your wallet/
kjett
kjett
Post  muddog899 January 11th 2016, 3:45 pm
thanks
Kjett
muddog899
Post  samiam January 11th 2016, 10:11 pm
you might also look at running an electric vacuum pump , I got one on my rig, makes a big difference
samiam
samiam
Post  460bronco January 12th 2016, 12:54 pm
What kind of vacuum do you have with your new build?
460bronco
460bronco
