Brake Master Cylinder Move?
I am moving the engine back, and need to move the manual brake master cylinder over about 1". My question is, is their a transition kit for moving over the master cylinder 1" to mount to the firewall?
67460- Posts : 384
Re: Brake Master Cylinder Move?
When I installed the BB in my maverick yrs.ago (stock firewall). I ran into the same problem. I installed a MC from a Ford Mini Van and had to angle it toward the left side by drilling the rt side bolt up about 1" to clear the Tall alum valve covers. Worked fine.
Mine is very close moving over is necessary, not sure if angling it will do the trick. I may only be able to get 3/4" of and inch due to the brackets that support the brake pedal.
67460- Posts : 384
also going to see if I can get at least 3/4" by moving the engine over.
67460- Posts : 384
» Master cylinder/brake pedal question
» brake line plumbing for ford ranger master cylinder.... on my f100....
» master cylinder
» T-BIRD MASTER CYLINDER
» Need help with the brakes on my 72 mark 4 lincoln
» master cylinder
