Master cylinder/brake pedal question
Master cylinder/brake pedal question Empty Master cylinder/brake pedal question
Post  HorsinAround April 26th 2013, 1:27 pm
Is a single cylinder ok for the drag truck or should I go with the dual master cylinder assy? Also, what ratio is recommended?
http://www.frontpagefab.com
Master cylinder/brake pedal question Empty Re: Master cylinder/brake pedal question
Post  jc10000rpm April 27th 2013, 1:09 am
what calipers are u using, here is some good info iv collected over time, these are the mopar style Master Cylinders u see used in kits, pick the bore diameter that suits your setup
Fenco M1983 used on 1984- 1990
dodge caravan 24mm bore and 3/8 flare threads
Fenco M1860 1-1/8 bore and 1/2 and 9/16 flare
Fenco M1822 1-1/32 bore and 1/2 and 9/16 flare --- 1985 chrysler 5th ave
jc10000rpm
