Alky carb setup....
Alky carb setup....
Got this 850 alky carb here. Tore into it and I noticed its got 92-94 jets in it and 0.120 orifices drilled directly above the jets.. Now that seems like an awful lot of fuel for a 850. I figured out the area of the jets, power valve restrictions, and the orifices drilled directly above the jets. I then figured out the area of all the orifices on my Gaerte 750 alky carb which has similar holes drilled directly above the jets also. My Gaerte carb's orifices are only 0.060 directly above the jets though. So after comparing the two even though the 850 is roughly 12% bigger its has roughly 32% more orifice area for fuel to flow. So my question is this carb setup way wrong or no? Does anybody have 850 alky carb setup similar to this one? Im wondering someone enlarged the orifices above the jets on this one or are they suppost to be this big?thanks
bluef100fe- Posts : 379
Re: Alky carb setup....
I think Rupert drills the holes in his, I have an 800 he did for me, big gas jets in fron w the holes, no jets in the rear............run it.
I had a carb done like that once. Same deal, secondhand, didn't know who modified it but it ran OK.
TJ
TJ
Tommyj466- Posts : 322
richter69 wrote:I think Rupert drills the holes in his, I have an 800 he did for me, big gas jets in fron w the holes, no jets in the rear............run it.
Start it and do a burnout?? LoL
I've never seen one done that way...BUT...if FabieAhole says it'll work ....I say Start it and do a burnout
56Tbird- BBF CONTRIBUTOR
mine did, bur then again it was on a 306, a qf 950 made more power on the dyno.......
» Alky carb vs. Alky injection
» Looking For A Alky Carb
» 2X4 Carb Setup
» Alky carb guys, HELP!
» Rupert alky carb
» 2X4 Carb Setup
» Rupert alky carb
