Wood-fired boilers/ hot water-heat
prosandguy
Diggindeeper
72mav
Well Ive had it!!!
Finally turned on my furnace. Thought my good buds here might have some build- info/etc on just making the boilers. I have all access to the other stuff. Not gonna pay the crazy prices for one though.
My house is five years old, and tight as heck. $600+ bucks every 2months for propane is just robbrery to me.....
Al
Al
72mav- Posts : 1081
Re: Wood-fired boilers/ hot water-heat
wow, i thought we had it bad @ 300/month for natural gas.
Oil furnace would even be cheaper. And they make a nice heat.
Wood is a PITA. but..cheap.
Diggindeeper- Posts : 800
My wood will be free. . Plus I can run it in my shop, which will be next to the boiler. Just tired of takin it in my Azz when it comes to fuel prices.
Al
Al
72mav- Posts : 1081
Al, my boss did his 2 winters ago, he said it paid for itself after the first year, he also has "free" wood. What all do you want to know?
prosandguy- Posts : 186
AL, Your going to Blow your self up
prosandguy wrote:Al, my boss did his 2 winters ago, he said it paid for itself after the first year, he also has "free" wood. What all do you want to know?
I just need the boiler build info. Thanks.
Al
72mav- Posts : 1081
bbf-falcon wrote:AL, Your going to Blow your self up
I dont plan on it Rick, I have some Good pipe-fitter guys whom can weld it for me.
Pays to have some freinds, being a fellow trades guy...
Al
72mav- Posts : 1081
At least he'll be warm
dirtbogger- Posts : 172
Al, we don't have the cold here that you guy's have, but a neighbor put in a insert, that goes in the fireplace and ties in to the central duct work and heats his whole house! and it's 99% efficient. It has a catalytic converter built in, so you get all the heat from your wood. I called him and he said it was manufactured by Consolidated Dutchwest. I've been there when it was in the 20's and he'd have to open a window or door because it would get too warm in the house. 2500 sq. feet Just trying to help!!Al Martin wrote:prosandguy wrote:Al, my boss did his 2 winters ago, he said it paid for itself after the first year, he also has "free" wood. What all do you want to know?
Al
Thanks ralph,
Only problem is I dont have a chimney. Just a 2inch section of PVC. Plus I dont want to run any big stove pipes either.
This system uses a hotwater coil in my ductwork. Then use the furnace as a air-handler. Cool setup.
Thanks again.
Al
Thanks again.
Al
72mav- Posts : 1081
I was looking into this too Al,
I looked at a bunch of web sites and found quite a few different concepts in firebox/boiler design. Their all low pressure boilers so there safe.
http://www.globalhydronics.com/index.html
http://www.econowaterstove.com/
http://www.wdheat.com/
http://www.thewood-doctor.com/index.html
http://www.woodsedge.us/default.aspx
I'm sure a clever guy like you could come up with a good design from these!!
I have heard of folks just using a car radiator for the heat exchanger in the house or shop.
Bill
Bill
billandlori- Posts : 2081
Al I'm getting ready to install one real soon.
The boiler I have was meant to be indoors so I'm going to build a shed out back for it.
I made my own insulated pex lines that are going inside 8" pvc pipe about 5ft underground. The boiler will be 75 ft from the house.
I need to get my butt in gear it's getting cold.
The total cost for my deal is somewhere around $2000 and the boiler was free.
Here's a site with lots of info.
http://www.arboristsite.com/index.php
mike
mike
f250mike- Posts : 628
Thanks Bill,Mike.
Ill check those out later gentlemen.
Momma "WANTS" her computer back
Regards.
Al
Regards.
Al
72mav- Posts : 1081
AL, Just tell MOMMA, she can have it when your finished
Yeah right...
I got it now!
I got it now!
72mav- Posts : 1081
» Increasing Plenum Volume on TFS A460 Tunnel Ram? Cheap power or waste of time?
» EPA says no more wood stoves/fireplaces?
» Switched from mech water pump to Moroso electric water pump
» pine wood derby tricks
» Got it fired up !
» Got it fired up !
