4.460 Bore Stock block
4.460 Bore Stock block Empty 4.460 Bore Stock block
Post  powerstrokeace February 28th 2013, 1:31 am
is there such a piston and ring package for this? Or could I get 4.442-4.445 pistons and rings?
Ace
powerstrokeace
powerstrokeace
4.460 Bore Stock block Empty Re: 4.460 Bore Stock block
Post  DanH February 28th 2013, 3:38 am
powerstrokeace wrote:is there such a piston and ring package for this? Or could I get 4.442-4.445 pistons and rings?
Ace
there are 4.470" piston/rings
DanH
Post  Lem Evans February 28th 2013, 10:04 am
Ace
The file fit rings are + .005" so you can use them in a 4.442", 4.443", etc. bore.....just gotta have a piston make.
Post  rmcomprandy February 28th 2013, 10:23 am
Stock production bore size for a Chevrolet 502 is 4.466" and there are 1/16" x 1/16" x 3/16" rings available; thinner ring sizes, I don't think so.
Post  Lem Evans February 28th 2013, 10:27 am
rmcomprandy wrote:Stock production bore size for a Chevrolet 502 is 4.466" and there are 1/16" x 1/16" x 3/16" rings available; thinner ring sizes, I don't think so.
Yep, the ring selection at the 4.466-4.470" bores is very limited.
Post  Paul Kane February 28th 2013, 1:23 pm
Ace
Ring packs for a 4.44X" and 4.46X" bore are readily available, although the 4.46X can get expensive (not a big deal if you need just a single set for a long-life engine).
Pistons can be made in any size; the shop recently had an engine with a slightly worn 4.625" bore, was power honed to 4.632", had pistons made for a 4.632" bore, and then used 4.625" +0.005" rings...ain't no thang.
Paul
