spring rate for bbf in foxbody ...28x10.5 tire car
yellowhorse7
5pointslow
spring rate for bbf in foxbody ...28x10.5 tire car  Empty spring rate for bbf in foxbody ...28x10.5 tire car
Post  5pointslow March 3rd 2013, 5:33 pm
iron head deal ..... say 700 hp .. stock style suspension car with a glide and trans brake
what springs for front coil overs 12 or 14 long and 150 or 175 rate ?? thanks
has racecraft drop spindles and baseline rear suspension if matters
Andrew
5pointslow
5pointslow
spring rate for bbf in foxbody ...28x10.5 tire car  Empty Re: spring rate for bbf in foxbody ...28x10.5 tire car
Post  yellowhorse7 March 3rd 2013, 7:02 pm
5pointslow wrote:iron head deal ..... say 700 hp .. stock style suspension car with a glide and trans brake
Andrew
14" for a BB car. 175 with that iron head.....
yellowhorse7
yellowhorse7
Post  Mike R March 3rd 2013, 8:29 pm
Tony, I'm looking at Strange single adjustables for the rear on my wagon. What would you suggest for springs, or can you point me towards someone who could help me? Not sure on the weight, but I'm guessing around 3000
Post  yellowhorse7 March 3rd 2013, 8:35 pm
Mike R wrote:Tony, I'm looking at Strange single adjustables for the rear on my wagon. What would you suggest for springs, or can you point me towards someone who could help me? Not sure on the weight, but I'm guessing around 3000
More info on car plz...
yellowhorse7
yellowhorse7
Post  yellowhorse7 March 3rd 2013, 8:39 pm
Start at 225-250# for a slick.
yellowhorse7
yellowhorse7
Post  Mike R March 4th 2013, 12:48 am
Fairmont wagon, Upr front suspension, tubular control arms with bushings, strange single adjustable struts with 14"180 lb springs. Mini tubbed, Wolfe offset single adjustable lowers, UPR double adjustable uppers, 8.8 rear with 4.10 gears, MT 28x12.5 ET streets. I'm in the process of doing thru floor sub frame connectors and planning on a 10 point cage. Power will be a 521 Blue Thunder head, approximately 13.3 to 1 compression with a PA C6. I currently have a Coan 3500 stall converter but I'll probably be sending it to Lenny a UCC for up grading after the motor has been dynoed.
Post  Rich Osmond March 13th 2013, 11:58 am
I have had good success with 175# on the front and as low as 110" on the rears depending on track conditions and whether I run DR or slicks.
Rich Osmond
Post  clodracer2000 March 19th 2013, 5:49 pm
Has anyone used the comp engineering front 175 spring? I gotta 85 notch with 429 iron headed c6, strange adjustable shocks on all 4, and upr 175 coil overs in back. I was wondering if the noise will sit too low with those springs...
clodracer2000
Post  whatbumper March 19th 2013, 5:52 pm
clodracer2000 wrote:Has anyone used the comp engineering front 175 spring? I gotta 85 notch with 429 iron headed c6, strange adjustable shocks on all 4, and upr 175 coil overs in back. I was wondering if the noise will sit too low with those springs...
i wouldnt think they would sit too low. we run less than that with our small block with a 70 lb turbo in the front bumper.
Post  clodracer2000 March 19th 2013, 6:29 pm
Guess ill try um out then... Very Happy
clodracer2000
Post  Rich Osmond March 19th 2013, 10:26 pm
I have run a lighter front spring as well - I think you will be ok.
Rich Osmond
