tire growth rate ???
+7
Larry Williams
Treeyasoon
Barney
11 posters
Page 1 of 2
Page 1 of 2 • 1, 2
is there a formula for tire growth ..... size vs. speed ??? and will a drag radial grow as much ?
Re: tire growth rate ???
bruno wrote:is there a formula for tire growth ..... size vs. speed ??? and will a drag radial grow as much ?
Rim width vs tread width will also effect the amount of tire growth.
DILLIGASDAVE- Posts : 2262
MT says 1.5 inch at 150 for their slick on the recommended rim, but as mentioned beadlocks, width of the rim etc. will affect it.bruno wrote:is there a formula for tire growth ..... size vs. speed ??? and will a drag radial grow as much ?
Barney wrote:MT says 1.5 inch at 150 for their slick on the recommended rim, but as mentioned beadlocks, width of the rim etc. will affect it.bruno wrote:is there a formula for tire growth ..... size vs. speed ??? and will a drag radial grow as much ?
is that any slick size ?
There are a couple of threads about this on the Bullet that I have saw....In the Drag Racing section I do believe.
It seems I remember reading that the DR will not grow like the slick.
Treeyasoon- Posts : 759
you after the clearance or gearing change Nick?
Just come on over to the dark side.....
richter69 wrote:you after the clearance or gearing change Nick?
clearancing .... i really want to try a 29.5 x 10.5s ... i believe that will give me the additional contach patch i need ...or even try the 295 drag radial 10.9 x 30.0 but the d/r weighs a porky 38lbs per tire compared to the 27lb slick ........ so i need too make sure i got 2" inches of clearance for the slicks to work ...there is zero growth on the drag radial deals
sawzall that shit...............make it fit............it swap the gear too.
It's not that hard to clearance the fenders. You will need some little pieces of aluminum and silicone to fill the gaps you make. Takes about 2 hours for both sides. Then you can fit any of those tires. Hell, we can fit a 29.5x10.5W tire.
whatbumper- Posts : 3024
the car is already mini-tubbed and shortened axles , the only problem is the wheels that i ordered this last time are the wrong offset ...... so i need a new set of wheels and then a set of tires
bruno wrote:the car is already mini-tubbed and shortened axles , the only problem is the wheels that i ordered this last time are the wrong offset ...... so i need a new set of wheels and then a set of tires
what size wheels and offset did you get?
Larry Williams- Posts : 884
I meant the front to rear clearancing that you have to do. You have to notch the lowers on both. For the taller tire to work.
The HOOSIER DOT Drag Radial in size 315-60R15 has 11.1" tread width, 29.7" tall and weighs 30#. Both the Hoosiers and Goodyears are considerably lighter than either the BFG's and M/T's. Unlike the BFG's and M/T's which are actually intended for street use, the Hoosiers and Goodyears warn that even though the tires are DOT rated- they are not meant to be driven on the street! If your having issues getting your slicks to hook, I doubt if it would be a good idea to try drag radials! My car is 99% a street car, so I ordered a new set of Hoosier 325x50x15 DOT drag radials for my car. From what I've heard from guys that run high powered cars in NMCA True Street, I'm confident that they will hook better than my current BFG's- BUT THEN AGAIN THAT ISN"T SAYING MUCH!!!!!!! Trim your quarter panels and run the tallest and widest slick that you can fit. But not too big, because Stephen says "BIG TIRES ARE FOR SISSIES!"bruno wrote:richter69 wrote:you after the clearance or gearing change Nick?
Gary
GTmustang- BBF CONTRIBUTOR
Larry Williams wrote:bruno wrote:the car is already mini-tubbed and shortened axles , the only problem is the wheels that i ordered this last time are the wrong offset ...... so i need a new set of wheels and then a set of tires
15 x 10 w/ a 5.5 bs ..and it has the wheel push right up against the fender ... ..i need a 6.5" bs and then i want to try the 29.5 x 10.5 s ....
i am using the 5.5 back space now will have to go to the 6.5 to lower the back of the car any. 15 by 10 5.5 bs now
richter69 wrote:sawzall that shit...............make it fit............it swap the gear too.
i still want to run some 1/4 deals too
then dont be surprised if you leave some 1/8th mile et on the table with it geared for the 1/4.................
so if i were to keep the same tire deal ... what gear would you run in my deal to optimize it for 1/8 mile
whats the trap rpm in the 1/8th?
6400-6500
it may be a deal the converter is too tight................you get it real aggressive down low either combo its gonna want that bigger tire......unless you are restricted to the 28 I would get the 29.5 on there.....then tune the gear and or converter and go from there.
whatbumper wrote:It's not that hard to clearance the fenders. You will need some little pieces of aluminum and silicone to fill the gaps you make. Takes about 2 hours for both sides. Then you can fit any of those tires. Hell, we can fit a 29.5x10.5W tire.
do you have any pics on what you are talking about
The radial tire cars are big here. I really doubt that some of them can get a #2 pencil between the quarter panel and tire and they do not rub.
Travis
Travis
TravisRice- BBF CONTRIBUTOR
Page 1 of 2 • 1, 2
» spring rate for bbf in foxbody ...28x10.5 tire car
» tire size back half frame kits tire width on 70 mustang
» Slick Growth
» Big tire/Small tire.....
» Coil Spring Rate
» Slick Growth
» Coil Spring Rate
Page 1 of 2
