Oil Pan Plug Tapped For Temp Sensor
Oil Pan Plug Tapped For Temp Sensor Empty Oil Pan Plug Tapped For Temp Sensor
Post  1faststang March 8th 2013, 9:19 am
I thought I've seen these on here before.. but I can't seem to find them. Is there a Oil Pan Plug actually made that has a bung to accept a Oil Temp Sensor??.. Maybe Lem sells them??. Thanks For your help!
1faststang
1faststang
Oil Pan Plug Tapped For Temp Sensor Empty Re: Oil Pan Plug Tapped For Temp Sensor
Post  Curt March 8th 2013, 11:43 am
All that I have seen have come from well intentioned racers. Just make sure you center it up when you get ready to drill. Arrow
Post  John Myrick March 8th 2013, 12:40 pm
I think he's looking for a NPT threaded adapter to go in place of the drain plug so he can screw the heater into.
Post  1faststang March 8th 2013, 1:38 pm
John Myrick wrote:I think he's looking for a NPT threaded adapter to go in place of the drain plug so he can screw the heater into.
Yeah pretty much.. Instead of drilling my oil pan and welding a bung in for a Oil Temp Sensor. I thought I seen something on here before where either someone used or sold a fitting.. or some sort of adaptor to fit this sensor in the oil plug drain.. or the plug itself. I maybe wrong though!. Smile
1faststang
1faststang
Post  John Myrick March 8th 2013, 1:52 pm
My oil temp fitting is a 3/8"NPT thread, so I'm sure there is a fitting out there that will work. I need to change the oil out this weekend so I'll check the threads in the pan.
Post  1faststang March 8th 2013, 2:16 pm
John Myrick wrote:My oil temp fitting is a 3/8"NPT thread, so I'm sure there is a fitting out there that will work. I need to change the oil out this weekend so I'll check the threads in the pan.
Awesome.. Thanks!
1faststang
1faststang
Post  rmcomprandy March 8th 2013, 7:41 pm
3/8 NPT is larger than a 1/2 x 20 bolt thread oil pan plug in most pans.
1/8 NPT is about 3/8" in diameter.
