Valve cover help!?!?!
I recently bought some professional products valve covers and these only 6 bolt holes and my heads have 7. Then i checked on ebay and half the valve covers have 6 bolt holes. I have dove heads on my 429. Whats goin on here? LOL
clodracer2000- Posts : 18
Re: Valve cover help!?!?!
clodracer2000 wrote:I recently bought some professional products valve covers and these only 6 bolt holes and my heads have 7. Then i checked on ebay and half the valve covers have 6 bolt holes. I have dove heads on my 429. Whats goin on here? LOL
Nothing out of the ordinary here. That's pretty much the way everyone in the aftermarket does it. It will be fine, no worries.
Nevs- BBF CONTRIBUTOR
My ford motorsports aluminum valve covers are the same way I just glued/rtv the gaskets to the valve covers not to the heads that way when I pull them the gasket stays with cover plus the gasket dont slip doen on the top where the bolt hole is missing
If you run a lot of vacuum in the crankcase, you should screw a little short stud in to the unused hole on the head, to prevent the gasket from being sucked in.
Just make it protrude 1/2 gasket thickness...
» valve cover studs for aluminum valve covers
» Valve cover Gaskets
» Any certain valve cover fit the P51 better than others?
» Moroso big block aluminum valve covers
» Valve cover help for the scj heads
