What octane fuel to run?
61coon
FORDMUD
whitefield
What octane fuel to run? Empty What octane fuel to run?
Post  whitefield March 14th 2013, 10:50 pm
On a 13.5 :1 engine with cast Iron heads 466 cubic inch what octane fuel should be used ?
whitefield
whitefield
What octane fuel to run? Empty Re: What octane fuel to run?
Post  FORDMUD March 15th 2013, 9:23 am
I have an iron headed 528 at 13.7. I ran vp113 last season. It may have been fine but I'm going to Q16 this season.
FORDMUD
FORDMUD
Post  whitefield March 15th 2013, 10:32 am
FORDMUD wrote:I have an iron headed 528 at 13.7. I ran vp113 last season. It may have been fine but I'm going to Q16 this season.
I wasn't for sure what to run as all of my other engines have been pump gas or no more than 11.5:1 motors . In those I always ran 93 110 or a mix of 93 and 110.
whitefield
whitefield
Post  61coon March 15th 2013, 10:37 am
Blake ran av gas in a iron headed 514 for 12 years. Should work fine for you.
61coon
61coon
Post  61coon March 15th 2013, 10:39 am
61coon
61coon
Post  61coon March 15th 2013, 10:43 am
Sorry about this double post.... Dang iPhone . Lol
61coon
61coon
Post  richter69 March 15th 2013, 10:51 am
methanol for the win............
Post  61coon March 15th 2013, 10:56 am
richter69 wrote:methanol for the win............
Thought you might say that. Lol
61coon
61coon
Post  whitefield March 15th 2013, 11:18 am
Which one of these fuels would work the best? I am planning on buying a drum in the next month . Very Happy
http://www.vpracingfuels.com/vp-drag-racing.html
whitefield
whitefield
Post  richter69 March 15th 2013, 11:19 am
use C12 or is you want a little more kick use the 113
if you can get it the Renegade 110+ is good stuff and a lot cheaper than VP. As soon as I burn all this VP NO2 I got I will switch over to the Renegade ............dang near 200 bucks cheaper per drum than VP
Post  whitefield March 15th 2013, 11:20 am
61coon wrote:Sorry about this double post.... Dang iPhone . Lol
You guy's are to high tech for me ! Still running the distructable flip phone!
whitefield
whitefield
Post  69F100 March 16th 2013, 11:47 pm
I ran the turbo blue 110 from the local Shell station at $7.35 gal before switching to alky
Post  richter69 March 16th 2013, 11:52 pm
Dude i got an iphone 3g...........
Post  J.Toney November 5th 2013, 1:19 pm
Corn fuel.....
J.Toney
J.Toney
Post  bronco911 November 5th 2013, 8:47 pm
richter69 wrote:use C12 or is you want a little more kick use the 113
X2. The bang for the buck is the Renegade 110+
bronco911
bronco911
Post  IDT-572 November 12th 2013, 4:04 pm
You need only run enough octane to keep the engine out of detonation. 110 should be enough for what your doing.
I have had several engines on the dyno that were 93 octane friendly and lost power with 110 or av gas. But 93 pump gas has more oxygen content.
Post  whitefield July 7th 2016, 10:55 pm
I have the one engine back together and wound up going with 112 renegade . The engine seems to idle and throttle better on the 112 than it did on Sunoco 110. Cool
whitefield
whitefield
Post  IDT-572 July 8th 2016, 9:00 am
I found that to be true also............. Wink
Post  whatbumper July 8th 2016, 10:01 am
We sell a lot of what VP calls Roundtrack. It is basically all the fuel left in the hose when filling barrels that gets dumped into a large tank, blended, and guaranteed to be a minimum of 107 but most of the time they say it's well over that. It has all their fuels blended in it but we don't see any inconsistency in tuning.
I sell it for $425 a barrel or $8.50 per gallon to the local circle track boys.
