What Octane or fuel to use ?
What Octane or fuel to use ? Empty What Octane or fuel to use ?
Post  RetroJim March 20th 2010, 1:17 pm
I am building my 460 and got a lot of parts in a deal . I got a real nice set of Pop up forged pistons . The guy told me he thinks they were like 11 or 11.5 to i compresson . I was looking for flat tops but got these in the deal with other parts I bought .
My question is will these run on pump gas of 93 octane ?
Hope someone can help !
Jim
RetroJim
RetroJim
What Octane or fuel to use ? Empty Re: What Octane or fuel to use ?
Post  '65 T-BOLT March 21st 2010, 9:54 am
93 with some octane boost! just my 3 cents...my 460 iron head engine is 11:1 compression stock and i mix cam2 and 93
'65 T-BOLT
'65 T-BOLT
Post  tall69 March 22nd 2010, 12:04 pm
I wonder if you can whack the tops of the pistons to make them flattops? I would think 25% 110 race fuel and 75% pump premium would be OK. The tune would have to be spot on though.
tall69
tall69
Post  dfree383 March 22nd 2010, 12:07 pm
whats the part number and whos pistons? What heads are you going to use?
You need to watch TRW / Sealed power domed pistons with some small chamber heads can go well over 13:1......
What Octane or fuel to use ? Empty E-85?
Post  511Fox March 22nd 2010, 4:30 pm
Is E-85 available Question
511Fox
Post  RetroJim March 23rd 2010, 11:06 am
I don't have any around here yet . I am sure there might be with all the race tracks in my area . I have the Lincoln Racway not 5 minutes from me for sprint cars and Quarter Aces Dragway about 45 mins and Maple Grove about 1.5 hours from me .
He is my problem , I am buildong the 460 for my 1937 Plymouth p/u and in Pa we need to go through a special inspection to get a title and tag for the car . I am thinking down the road that if it will be too much BS then I will build a mild drag truck . I got these pistons in the deal . TRW , L2443 N--Standard bore . I have tried to find the compression out and the best I have come up with is 10.5 to 1 .
I would like to use them if possible but if I need 100 octane I need to either buy 100 octane or use additives to raise the octane .
This is what I am trying to find out .
Jim
Looking for a 460 crank !
RetroJim
RetroJim
Post  dfree383 March 23rd 2010, 11:57 am
If you have Small Chamber Heads (DOOE-R, DOVE, Ect) you will be over 13:1 using those pistons or in the 10.5:1 range with the bigger chamber stuff (D3's and such)
Good news is the domes can be cut off and you can get it down to 11.5:1 or so with the small chamber stuff.
Post  RetroJim March 23rd 2010, 12:21 pm
The guy did have the engine with those pistons running on pump gas . It was in a tow truck and that thing flew ! It had a Crane 266 cam in it as I have that also .
The heads is the mystery to me so far as the # is D VE. I can see the second letter , It's gone ! I belive they are DOVE heads but not sure . The pistons are on DOOE rods . Wish I could tell which heads they are .
Jim
RetroJim
RetroJim
Post  dfree383 March 23rd 2010, 12:25 pm
Can you get them CC'd, 72-75 = Early and 90-94 = Later
Post  RetroJim March 23rd 2010, 12:32 pm
Don't know how , I know the measurments but have no way of doing it .
Like I said I believe they are DOVE heads buy the rest of the parts that came off the engine but no guarantee on that one .
Jim
RetroJim
RetroJim
Post  tall69 March 23rd 2010, 2:51 pm
RetroJim wrote:Don't know how , I know the measurments but have no way of doing it .
Jim
Is the motor together at this point? I guess I'm confused. You ask what octane fuel will be required for your build, but you're unable or unwilling to get such a crucial piece of information? Please, I'm not trying to come across as a jerk, but there are many factors that determine what octane is required for a motor to steer clear of detonation. The top two (IMO), are static compression and cam profile (thus dynamic compression).
tall69
tall69
Post  RetroJim March 23rd 2010, 2:55 pm
Jim
I got this in a deal of parts ! All parts !
Jim
RetroJim
RetroJim
Post  tall69 March 23rd 2010, 3:04 pm
RetroJim wrote:I got this in a deal of parts ! All parts !
Jim
Take a head to a local machinist and have him (or her - equal opportunity!), cc a chamber.
tall69
tall69
Post  RetroJim March 23rd 2010, 3:33 pm
I guess I will more than likely just have them shaved to flat tops so I can use pump gas for safety . I just hate to do that to a piston .
I will have my machinest check the combustion chamber for the cc also when he does the heads . I am getting bigger intake valves installed too . I know that when you do by pistons they usually say if you have these CC heads then you will have this as a compression ratio . That is what I was trying to find out right now . Can't find that anyplace !
Thanks,
Jim
RetroJim
RetroJim
Post  dfree383 March 23rd 2010, 4:16 pm
I already told you what it will be, you need to figure out the CC of your combustion chambers.
13:1 +/- with the Small Chambers with the Dome
11.5:1 +/- on Small chamber heads w/o the Dome
10.5:1 +/- with Big Chamber heads with the Dome
9:1 +/- with Big Chamber Heads w/o the Dome
Post  RetroJim March 23rd 2010, 4:21 pm
Yes but I don't have a machinest that is that fast ! Was just looking for something close so I know where I stand .
I do have some D3 heads that I could use the with .
Thanks again !
Jim
RetroJim
RetroJim
Post  dfree383 March 23rd 2010, 4:32 pm
D3's = about 10.5:1 with the domes on.
Post  RetroJim March 23rd 2010, 6:48 pm
Well I decided to go and measure the intake valves to see if that helps to figure out which heads I have before I go to the machinest .
Well to my surprize the intakes are 2 & 1/8" . The heads have never had any work and they have no emission on them .
Jim
RetroJim
RetroJim
