Filing rings
+9
Dave C.
512Fairlane
bigjohn2007
13 posters
Page 2 of 2 Previous  1, 2
Filing rings - Page 2 Empty Re: Filing rings
Post  richter69 March 27th 2013, 5:22 pm
I used the n/a settings for mine, been fine w a 200 shot, just go by what the instructions say.
Post  bigjohn2007 March 27th 2013, 5:44 pm
Went out side and got the rings[Akerly&childs] lem sent me and looking at the instructions this is what it says for nitrous oxide top ring-add .0008 per inch of bore for each 100 hp of nitrous used.Do i need pistons to or just learn how do the math that the rings recommend?
bigjohn2007
bigjohn2007
Post  bigjohn2007 March 27th 2013, 5:51 pm
3 boxs inside ones got DM FF other box has CI FF on it and last box OIL LT
bigjohn2007
bigjohn2007
Post  Lem Evans March 27th 2013, 5:56 pm
.024" should work for the top ring if you only got a 200 shot.
Post  bbf-falcon March 27th 2013, 6:32 pm
bigjohn2007 wrote:3 boxs inside ones got DM FF other box has CI FF on it and last box OIL LT
Read your sheet.It will give you all the info you will need. Smile
Post  bigjohn2007 April 7th 2013, 2:24 pm
Im lost as always lol the instructions says ADD .0008 to top ring and .0007 to second ring for each 100 hp of nitrous used.So if im going shot 250 nitrous and the bores 4.420 how do in do the math.The paper came with piston says for drag race-power adder with 2618 material .001-.002 more.
bigjohn2007
bigjohn2007
Post  69F100 April 7th 2013, 3:49 pm
bigjohn2007 wrote:Im lost as always lol the instructions says ADD .0008 to top ring and .0007 to second ring for each 100 hp of nitrous used.So if im going shot 250 nitrous and the bores 4.420 how do in do the math.The paper came with piston says for drag race-power adder with 2618 material .001-.002 more.
I know when I filed my rings the pistons called for one thing and the rings for another my pistons called for more gap on the rings than the sheet that came with the rings.So I went with what KB said on the pistons which was .002 more than what the rings called for.I have herd the KB needs more gap to keep from top ring lad from braking.
Post  bigjohn2007 April 7th 2013, 6:55 pm
Going call Akerly&Childs this week
bigjohn2007
bigjohn2007
Post  rmcomprandy April 7th 2013, 8:33 pm
Those numbers are multiplied by the bore size in inches.
A 4.420" bore would add .0008" times 4.42" for an additional .0035" per for every 100 horsepower of nitrous so, .0035" x 2.5 = .00875", would be the ADDITIONAL gap added on the top ring for a 250 shot of nitrous.
Do the same multiplications for the second ring but, using .0007" per inch of bore instead.
Post  bigjohn2007 April 8th 2013, 4:46 pm
Thanks very good detail but how do i get the first gap size # to add that to?
bigjohn2007
bigjohn2007
