build help
+7
LivermoreDave
toytroy
11 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: build help
dfree383 wrote:"Port Matching" isnt worth much of anything, You need to get into the bowls and blend everything and get a proper valve job if your looking for results. Along with some bigger valves of appropriate material for the application.
I still think you better off getting some SCJ heads, over reworking / rebuilding some dove heads for absoulte bang for the buck.
I understand that port matching isn't gonna be a huge differance in power, its just something id like to do. I'm not pro at "working" heads and I haven't found a great machinest around my area yet. Once again, I'm not looking for huge power numbers and I already have a set of d0ve heads that would just need some freshing up. I do understand that scj head would be a superior choice but, once again, I'm not looking for big numbers nor do I have a set. I guess I'm more of a humble racer as I see it in my head. I don't need the biggest and baddest car, just one to make a smile apear at the end of the day. I guess I should have mentioned that the nearest 1/4 track is 2 hours away and nearest 1/8 is 1 hour. So with my work schedule and 3 kids, actually making it to a track is gonna be slim compared to others so I don't want butt loads of money just sitting, not getting used.
toytroy- Posts : 15
Re: build help
Its your money do what you want, but your going to be disappointed and regretting spending all the money on the DOVE heads later when you want to go faster.
Re: build help
Troy I understand, some of the most fun I ever had was with a old engine with D2VE heads on it.
Sometimes you do what you have to do with. I'm glad to see you doing what you want, have fun bud.
Re: build help
dfree383 wrote:Its your money do what you want, but your going to be disappointed and regretting spending all the money on the DOVE heads later when you want to go faster.
You keep saying that I'm gonna spend a lot of money on the d0ve heads. I'm not sure why due to, the only thing I'm gonna really need to do is replace the springs, retainers ect... which I'm guessing will be around $300 tops if I do go with a flat tappet cam. To me, that doesn't seem like a lot of money. Now, if I was going to replace everything on the heads and do a full port/polish job, then yes, there would be a lot of money spent but, that's not what I'm doing. I do thank you for your input and all suggestions are always concidered do to I haven't got the motor put together yet.
toytroy- Posts : 15
Re: build help
IDT-572 wrote:Troy I understand, some of the most fun I ever had was with a old engine with D2VE heads on it.
Thanks.
toytroy- Posts : 15
Re: build help
I ran 10.30's w some junk doves...... n/a at that. not everyone needs alum heads.
Re: build help
So have I, but when you don't have access to a good machine shop and can't do a lot yourself, the aluminum aftermarket stuff is a better alternative to working over a set of factory iron to get similar performance. Machine work and parts are not cheap for most people.richter69 wrote:dfree383 wrote:Its your money do what you want, but your going to be disappointed and regretting spending all the money on the DOVE heads later when you want to go faster.
Re: build help
toytroy wrote:dfree383 wrote:Its your money do what you want, but your going to be disappointed and regretting spending all the money on the DOVE heads later when you want to go faster.
Typical 40+ year old heads are wore out and generally at least need guides, add a valve job, surface clean up, Valves, Springs, retainers, Locks, Guide plates and studs (+machining for them) you will be in them for very close to or over a grand at a reputable shop, using quality parts.
I'm not against using them, I've done it a number of times, but if your want maximum return for your investment and room for future growth...... they are not the way to go.
Re: build help
dfree383 wrote:toytroy wrote:dfree383 wrote:Its your money do what you want, but your going to be disappointed and regretting spending all the money on the DOVE heads later when you want to go faster.
I talked to the guy last night I got them from and he told me that he had them completely re done when he was running them but, he used a roller cam so I ill have to change out the retianer, springs ect... Its not that I'm uncapable of rebuilding the heads, I just don't have the machinest/skill to do any of the machine work. Also, I guess I'm trying to not go over board on power due to the budget I have. The more hp/tq the motor makes, the more I'm gonna have to beef up everything else. The thing I'm looking at too is, to get some scj heads to my door is gonna be between $1600-2000. That's between $600-1000 more then it would cost to fully redue the d0ve's and on a budget that can be intake, rockers, push rods, cam/lifters and possibly a used carb. I know the scj would be the best for making power and growing but, I don't believe they are my best bet this point in time. Like I've said, I do appreciate the time your giving and knowledge.
toytroy- Posts : 15
Re: build help
Sometimes people just need a little guidance to help them use or run what they already have! Money is the reason why some of us can't get what parts we want or is suggest for our hot rods. Build it and have fun with it my most fun days was running my 68 Torino and my old 72 F100 . They were fun streetable Vehicles. Good luck
whitefield- Posts : 2244
Re: build help
I need to get off my ass and start on my baller build lol, will have easily less than 15-1600 bucks in the whole deal....... carb to pan. waterpump to flywheel.
Re: build help
Sunday morning Wes Littrel drove to Glasgow, Ky. and picked up a set of D0 & C8 heads.....he turned down a set of D2VE heads You need to talk to the boy.
Re: build help
Lem Evans wrote:IDT-572 wrote:Troy I understand, some of the most fun I ever had was with a old engine with D2VE heads on it.
You seen them run at the first BBF bash hi speed boat anchors.................
Re: build help
Some times it's not the hardware..... It's the wing nut building the bullet...........
Re: build help
whitefield wrote:Sometimes people just need a little guidance to help them use or run what they already have! Money is the reason why some of us can't get what parts we want or is suggest for our hot rods. Build it and have fun with it my most fun days was running my 68 Torino and my old 72 F100 . They were fun streetable Vehicles. Good luck
I have to agree. ToyBoy,I understand your situation.If that's what you have,and that's all your budget w/raising family can afford,then you use what you have for now. Because if you put your build off because you don't have the funds for the latest and greatest parts you might never see it finished. Use what you have for now and take care of the family. Believe me,you will have more fun w/it. We are here to help you along.
Re: build help
bbf-falcon wrote:whitefield wrote:Sometimes people just need a little guidance to help them use or run what they already have! Money is the reason why some of us can't get what parts we want or is suggest for our hot rods. Build it and have fun with it my most fun days was running my 68 Torino and my old 72 F100 . They were fun streetable Vehicles. Good luck
Yep, pretty much sums up why mine has taken forever to build LOL. You do what you can with what you have... Main thing is have fun doing it! ---RED
61coon- Posts : 1824
Re: build help
The kids will still be around and remember what Dad sacrificed long after the cars are gone.
Page 2 of 2 • 1, 2
» 580 build P-51 build ideas
» No rules BBF nitrous build - Let's build it
» 408/418W build... what would you build?
Page 2 of 2
