stock cam specs
stock cam specs
anyone know the stock cam specs on a 69 460? im guessing the rockers are 1.73 on the older engines too?
bigblockfox83- Posts : 11
Re: stock cam specs
form what I have gathered all 460 and 429 had 1.73 ratio rockers from the factory I am sure if I am wrong they will correct me
Re: stock cam specs
Here ya go...The first cam is the stock one.
http://www.network54.com/Forum/267359/thread/1253405075/last-1253407644/Factory+and+FRPP+camshaft+specs
res0rli9- BBF CONTRIBUTOR
Re: stock cam specs
69F100 wrote:form what I have gathered all 460 and 429 had 1.73 ratio rockers from the factory I am sure if I am wrong they will correct me
Not here to correct 69F100, just add some info . The early 429-460's had 1.75-1 ratio rockers, from 68-71 and were rail type rockers with positive stop screw-in rocker studs. Todd
aquartlow- Posts : 169
Re: stock cam specs
so does anyone know if the early 68-69 cams are different then the later 70s cams?
Re: stock cam specs
Go to the bottom.
C8SZ-6250-A Thunder Jet and later stock hydraulic cam
September 19 2009, 5:08 PM
256°/270° @ SAE - 193°/206° @ .050" - .253"/.278" lobe lift - .443/.487 valve lift - 110°/116° lobe centerlines - 113 LSA
Intake opens 16° BTDC
Intake closes 60° ABDC
Exhaust opens 70° BBDC
Exhaust closes 20° ATDC
Overlap 36°
Additional notes:
1) The early timing chains are straight up, so that the camshaft is installed in the engine from the factory at 110° intake centerline.
2) The retarded production timing set retards the camshaft 4 camshaft degrees, (8 crankshaft degrees), so that the camshaft is installed in the engine from the factory at 118° intake centerline.
3) The specs that Ford lists for light trucks is from 1968 to 1992 and is a superseded camshaft part number E3TZ-6250-B; used in ALL Hydraulic lifter Ford Motor Company's remanufactured 385 engines. The part number for the original 1968 to 1972 engines is C8SZ-6250-A which is the same as Ford/Lincoln Mercury passenger car engines and no different specs are listed.
Overlap 36°
Additional notes:
Re: stock cam specs
ok so its the same just retarded timing sets make the difference. thats good info to know. on a 302 and 351 the pre 72 cams are a bit more aggressive then the smog cams. thanks
» Dove-heads
» cam specs for bbf
» U.S. Nationals Stock/Super Stock Qualifying Sheets
» Ignition timing with SCJ heads
» question about stock 1971 stock block
» cam specs for bbf
