Dove-heads
Dove-heads
I have 3 Dove-C heads. Bare, no valves, no studs, no springs. Been sitting in the shop for years. 100.00 ea. plus shipping
Bob
Bob
Godzilla- Posts : 92
7.5L 460 stock specs.
Hi, I was wondering if these heads will fit on my stock engine block. It's an 86 F-250 with a 7.5L 460 block. The cam, pistons everything is stock. I'm just doing a rebuild on it cuz it sat for 2 years and the old manifolds were ceased into the original heads. The originals were D3VE A2A heads. If the heads you got for sale here will fit my engine I would definitely want them. Thank u in advance for your time.
Jason
Jason
86F250XLTLariat460- Posts : 1
Re: Dove-heads
They will fit fine. Will need hardened seats for UL gas. Will raise CR also. Will need to change your rocker setup also. The DoveC's have screw in studs.
Dove C's
The heads will fit fine. They are bare, so you will need "everthing". You can expect to have 400.00 plus invested in a good working set of heads.
Bob
Bob
Re: Dove-heads
still have the heads
fordmanmatt- Posts : 33
» dove-c heads
» DOVE C heads plus
» 429/460 HEADS SCJ CJ DOVE A,C
» dove-c heads
» dove-c heads
» DOVE C heads plus
» dove-c heads
