King Bearings
bigjohn2007
King Bearings Empty King Bearings
Post  bigjohn2007 April 7th 2013, 1:28 pm
What are u guys opinion on these bearings i was going use them on a 6.8 Scat rod. Part#CR849HP STD.
bigjohn2007
bigjohn2007
King Bearings Empty Re: King Bearings
Post  dfree383 April 7th 2013, 1:36 pm
they work fine.
Post  69F100 April 7th 2013, 1:36 pm
John I ran King bearings in my 460 and haven't had any problems out of them I run the passager car bearings not the race bearing,I have them in my 552 also . They are good bearings from what I have seen from the ones I have run I am sure some will say they not any good.I am also interrested in what other say about them also come this winter I will pull the bottom end down and check them to see how they look.
Post  bigjohn2007 April 7th 2013, 1:54 pm
sounds good
bigjohn2007
bigjohn2007
Post  Curt April 7th 2013, 6:34 pm
Good Stuff!
Post  rmcomprandy April 7th 2013, 8:39 pm
The KING bearing with the SI added to the end of the part number are satisfactory bearings. The ones without the SI are merely a rebuilder's bearing and not for high performance use.
This applies to their regular line of bearings ... the "Performance" line of bearings are all good for a high horsepower engine.
Post  bbf-falcon April 7th 2013, 8:45 pm
rmcomprandy wrote:The KING bearing with the SI added to the end of the part number are satisfactory bearings. The ones without the SI are merely a rebuilder's bearing and not for high performance use.
Yep,I agree. Very Happy
Post  Lem Evans April 8th 2013, 8:01 pm
"Part#CR849HP"
The HP suffix tells that the bearing is a race grade bearing.
