9in rear
prosandguy
61coon
pigs521bbf
9in rear Empty 9in rear
Post  pigs521bbf April 16th 2013, 6:44 pm
so i just got a 9in rear end from a guy.. i was free but i need help i.d
on the 3rd member, casting number is d2aw a?
please help
pigs521bbf
9in rear Empty Re: 9in rear
Post  61coon April 16th 2013, 9:50 pm
Are you wanting to know the gear ratio or what?
61coon
61coon
Post  schmitty April 16th 2013, 9:57 pm
If you are going to run a T-brake, you better build it like a brick crapper. Back brace aftermarket axles, 35 spline minimum, and a real good through bolted third member.
Post  pigs521bbf April 16th 2013, 10:26 pm
Yea i would like to know what year this 9in is.. what size is the case 2.891 , 3.062??
pigs521bbf
Post  prosandguy April 16th 2013, 10:35 pm
schmitty wrote:If you are going to run a T-brake, you better build it like a brick crapper. Back brace aftermarket axles, 35 spline minimum, and a real good through bolted third member.
I'm not saying it will work for everybody, but
I ran an "N" case, bored out to a 3.250 side bearing, with 31 spline Moser axles, leaving off my transbrake at 6300. I didn't back brace it or anything, but it was shorter than factory so that probably helped too.
as far as the bearing size on yours, just tear that thing apart and look it over. You are going to anyway, might as well get into it now.
prosandguy
prosandguy
Post  61coon April 16th 2013, 10:55 pm
The small-bearing 9-inch housing has 3/8-inch brake backing-plate bolts, Large-bearing, 9-inch housings have 7/16-inch brake backing-plate bolts.
61coon
61coon
Post  68formalGT April 17th 2013, 12:47 am
61coon wrote:The small-bearing 9-inch housing has 3/8-inch brake backing-plate bolts, Large-bearing, 9-inch housings have 7/16-inch brake backing-plate bolts.
That's some GREAT info!! Never knew that, learn something new every day. Thanks 61coon.
Post  res0rli9 April 17th 2013, 6:36 am
Here ya go...go to the bottom-many page's. you'll find it.
http://www.fordification.com/tech/rearends_ford01.htm
Post  kjett April 17th 2013, 7:33 am
And when you want to really make sure them 35 spline shafts don't spit out the ends, they make 1/2" t-bolts Shocked
kjett
kjett
Post  61coon April 17th 2013, 9:49 am
No problem man! Pretty quick way to identify one, provided you can get the brake drum off. LOL
61coon
61coon
Post  pigs521bbf May 10th 2013, 10:11 pm
sorry i know this sounds dumb.. but can you maybe send a picture for me, so i understand a little more...
pigs521bbf
Post  schmitty May 10th 2013, 10:45 pm
There were large bearing ends with 3/8" bolts in some truck and van applications. I've tore into a couple of them, and it's only a drill bit fix to make them 1/2".
Post  61coon May 10th 2013, 10:49 pm
Check out this link... It has pics of just about everything on a 9".
http://www.kevinstang.com/Ninecase.htm
61coon
61coon
Post  whitefield May 10th 2013, 11:02 pm
schmitty wrote:There were large bearing ends with 3/8" bolts in some truck and van applications. I've tore into a couple of them, and it's only a drill bit fix to make them 1/2".
X2 van is what I got my fairlane rearend out of !
whitefield
whitefield
Post  bbf-falcon May 11th 2013, 2:09 am
Good info Red,Thx
