need to know what valve springs go with my camshaft...
need to know what valve springs go with my camshaft... Empty need to know what valve springs go with my camshaft...
Post  racinghabbit Fri 26 Apr 2013 - 14:00
solid roller camshaft, in a full race engine
Lift .702 INT/EXh
duration @50 -272int, 276exh.
lobe seperation 110degree
valve adj. .022
What kind of spring pressures do i need????
racinghabbit
racinghabbit
need to know what valve springs go with my camshaft... Empty Re: need to know what valve springs go with my camshaft...
Post  Lem Evans Fri 26 Apr 2013 - 14:10
What kind of installed ht. can you get?
Post  rmcomprandy Fri 26 Apr 2013 - 14:18
Full Race Engine...?
Along with your spring installed spring height ... What is the valve material and what RPM level do you expect to achieve?.
The aggressiveness of the camshaft lobe profiles is important, also.
Post  racinghabbit Mon 29 Apr 2013 - 12:36
Full race engine...
Currently I have a set of PRC-1800 Valve springs in the heads and there tired...
install hight @ 2 in...
racinghabbit
racinghabbit
Post  BigBlockRanger Mon 29 Apr 2013 - 16:36
What does the cam manufacturer/grinder recommend?
Post  racinghabbit Mon 29 Apr 2013 - 17:30
comp told me to use 947-16 springs...
they said the cam calls for 250 seat pressure and 600 pressure open at .700 lift.
racinghabbit
racinghabbit
