aluminum 6.800 rods
stroker533
aluminum 6.800 rods Empty aluminum 6.800 rods
Post  stroker533 May 6th 2013, 11:06 am
Looking for a good set of aluminum 6.800 length rods 2.200 big end and 0.990 small end
stroker533
aluminum 6.800 rods Empty Re: aluminum 6.800 rods
Post  Frank Merkl May 16th 2013, 1:08 am
I've got a real nice set of Grodens but there 6.835 " low runs (25) Big ends still round as are the pin ends $350 and I have a couple of good sets of 6.800 Venoilia's but they have the chevy offset on the pin end and they still check good $300 a set
Post  bruno May 16th 2013, 10:11 am
got a set of r and r pro billet , 6.8 i will have to get you the other dimensions fro Phillip at Oakley Motor sports
http://WWW.CKRME.COM
Post  Curt May 16th 2013, 10:14 am
I have a set of Bill Millers for $300.00
aluminum 6.800 rods Empty I might be intersted in those rods
Post  57custom July 8th 2013, 10:28 pm
if the fellow that posted this does not buy them. I have a set of 6.7 H beam eagle rods and have found out that nobody has stock pistons for 6.7 rods to use with a 4.3 crank. So I gotta either buy some new rods or used ones with the 6.8 size and the .990 small end and the chev size big end. This is for a low compression build that I am putting together for a spare.
57custom
57custom
Post  richter69 July 9th 2013, 4:52 pm
bruno wrote:got a set of r and r pro billet , 6.8 i will have to get you the other dimensions fro Phillip at Oakley Motor sports
hardly used ^^^^ lol
Post  fatal addiction July 9th 2013, 6:30 pm
I have a set of 6.750
fatal addiction
fatal addiction
aluminum 6.800 rods Empty I am going to NMRA/NMCA race at Joliet Ill.
Post  57custom July 9th 2013, 10:32 pm
this weekend and if I can't find anything I will get back to you guys. Thank you.in fact even if I do find something I will post for the info for you guys that have responded so far.Surprised
57custom
57custom
Post  dirtybird545 July 15th 2013, 7:50 pm
57custom wrote:if the fellow that posted this does not buy them. I have a set of 6.7 H beam eagle rods and have found out that nobody has stock pistons for 6.7 rods to use with a 4.3 crank. So I gotta either buy some new rods or used ones with the 6.8 size and the .990 small end and the chev size big end. This is for a low compression build that I am putting together for a spare.
Probe has a 1.45c/h dished piston for your combo. 10.5/1 with 75cc head and around 8.5/1 with 95cc IIRC.
dirtybird545
aluminum 6.800 rods Empty Thanks for the info
Post  57custom July 16th 2013, 2:46 pm
on the Probe pistons. I checked with them and just ordered a set and supposeibly will be here around the end of the month then I can begin
assembling the 521. The info on this site is great.
57custom
57custom
