aluminum rods
aluminum rods
Is there any clearancing needed to run aluminum 6.7" rods with a 4.5" crank in a dove block?
mudtrucker- Posts : 160
Re: aluminum rods
Yes and the amount of clearancing will depend on the brand of rod as they are not all made the same in the bolt area.
gt350hr- Posts : 662
Re: aluminum rods
BME 396 no grinding, BME 426 some but not a lot of grinding.
DaveMcLain- Posts : 399
Re: aluminum rods
DaveMcLain wrote:BME 396 no grinding, BME 426 some but not a lot of grinding.
How about on an A460 block?
68formalGT- Posts : 865
Re: aluminum rods
In an A-460, BME396 a very small grind at the bottom of the cylinder, BME426 more grinding in the pan rail area.
Re: aluminum rods
DaveMcLain wrote:In an A-460, BME396 a very small grind at the bottom of the cylinder, BME426 more grinding in the pan rail area.
Thanks Dave, I have BME396 rods.
Re: aluminum rods
68formalGT wrote:DaveMcLain wrote:In an A-460, BME396 a very small grind at the bottom of the cylinder, BME426 more grinding in the pan rail area.
My friend Wes became a fan of the Big Block Ford engines when he saw me putting together a 557 with aluminum rods in a DOVE block with no grinding. He was amazed.
» Grp Aluminum RODS
» Aluminum rods
» Connecting rods 6.700 vs 6.800... aluminum VS steel insight please?
» aluminum rods???
» aluminum 6.800 rods
» Aluminum rods
» aluminum rods???
