Aluminum rods pro's and con's
Mark O'Neal
57ford custom
I am going to update my engine this winter and need to know the pro's and con's of aluminum rods in a 98% drag and 2% street use engine. I have a 466 early block engine which now has iron cobra jet heads and it is coming out this winter. I am going to do a stroker either 4.3 or 4.5 stroke haven't decided on that yet. I have Kasse P51 heads and a roller cam that will replace the flat tappet came that is already in it. This engine made 596hp in its present condition. It has a well modified Weiand tunnel ram with 2 elelbrock 750 carbs and it runs good for a 3600 pound 63 fairlane. So back to the rods, need the good and bad info. Also should I worry about the shorter block cylinders versus the later blocks. This block has been converted to 4 bolt mains on the center 3 mains. I have done a 545 a few years ago but can't remember what block I used on that one but think it was out of a 76 merc but not sure. Its still running good with the 4.5 crank I put in it then. With flat top pistons I think it will still be around 12 to 1 compression. I run it now with 110 octane.
57ford custom- Posts : 107
Re: Aluminum rods pro's and con's
57ford custom wrote:I am going to update my engine this winter and need to know the pro's and con's of aluminum rods in a 98% drag and 2% street use engine. I have a 466 early block engine which now has iron cobra jet heads and it is coming out this winter. I am going to do a stroker either 4.3 or 4.5 stroke haven't decided on that yet. I have Kasse P51 heads and a roller cam that will replace the flat tappet came that is already in it. This engine made 596hp in its present condition. It has a well modified Weiand tunnel ram with 2 elelbrock 750 carbs and it runs good for a 3600 pound 63 fairlane. So back to the rods, need the good and bad info. Also should I worry about the shorter block cylinders versus the later blocks. This block has been converted to 4 bolt mains on the center 3 mains. I have done a 545 a few years ago but can't remember what block I used on that one but think it was out of a 76 merc but not sure. Its still running good with the 4.5 crank I put in it then. With flat top pistons I think it will still be around 12 to 1 compression. I run it now with 110 octane.
Other than a limited life expectancy the biggest con for aluminum rods in a stroker engine is just plain physical SIZE.
and the biggest pro is............
gimme a minute, I'm thinkin'........
Mark O'Neal- Posts : 286
they're not as hard on the block when they exit?Mark O'Neal wrote:and the biggest pro is............
cool40 wrote:they're not as hard on the block when they exit?Mark O'Neal wrote:and the biggest pro is............
You'd think that until you saw the block that hunk of a aluminum rod got between the #1 rod throw and the pan rail. Shoved the side off the block....oil filter mount pad and all.
Lem Evans wrote:cool40 wrote:they're not as hard on the block when they exit?Mark O'Neal wrote:and the biggest pro is............
Well, I appreciate the fact that you didn't send me any of those aluminum devils...
cletus66- Posts : 865
cletus66 wrote:Lem Evans wrote:cool40 wrote:they're not as hard on the block when they exit?Mark O'Neal wrote:and the biggest pro is............
I used to make them,and I don't miss them.....either.
I am working on having the Probe line manufactured for me.
Thought about you the other day, It's been a while.
enough of the frivolity guys and I do have a sense of humor:D but am really looking for good sharp info. This most likely be the last expensive engine I build and I want it to last like the 545 that I built a few years ago. For all you OLD guys I am 77 years old and still racing and to me a .050 or so is a good light. I will quit racing when I can't get over the roll bar anymore. So please let me hear the good and bad info. And at the possible 750 na hp it shoud make and maybe at the end of the day I might like to run a 9 as my car is only good for a 10 flat now and a 9 is only a 100 shot away. Lem I have bought parts from you so you know I am not a troll or poser or whatever one calls them. I also take this car to a show once in a while and I have a little sign on the windshield that says."this car may not be as pretty as yours but it is way way faster" and in that vein I may send the intake out to (Induction Solutions) and have them put a fogger on it for shock and aww to go with the 2 cheater plates on it now that hasn't been needed so far. There is an 1/8 mile track in our area that has a couple of street races that I think they relax the rules a bit and it looked fun when I went to the second one as a spectator this year.
If it were my money I'd use a steel rod. You'll get more passes out of them.
Not as experienced as Lem or Randy but for your application steel would be my choice . If you were talking 350+ of nitrous on top of 750 motor i would say aluminum .
wayne
wayne
wayney- Posts : 187
I'm making something north of 1000 NA hp with a steel rod shifting @7800. I wouldn't consider aluminum for anything NA unless maybe something over 10,000 rpm but probably not then. JMO...
57, I think all the guys WERE giving you good info...just had a bit of humor sprinkled in. A little sifting will separate the jokes from the pearls. It all sounded like "Use steel rods." to me.
maverick- BBF CONTRIBUTOR
on an eng that runs higher rpm 8000 and up we change the alum rods 120 passes avg
steel rods last longer,but have dated life also in higher hp builds.
2 engs built the same except for 1 with alum rods The later WILL BE quicker because of the acceleration rate will be faster .
BOSS 429- Posts : 2372
The toughest requirement you have with aluminum rods is the requirement to change them out one run before they break. Oil temperature is critical, which makes them iffy for any street use in an engine that makes higher oil temps, whereas they're fine in boat where making heat is a bigger issue than losing it.
The 73,000 lb Tensile Yield Strength (7075-t6) at ambient temperature drops to 27,000 at 300* (7076-T6 is actually better, in that it has more elasticity) but the only ones I ever knew to use it was Superod, but they vanished soon after we divested ourselves of it.
Here's some hard data.....enjoy!...
https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19930091014.pdf
Thank you guys for the help with this decision as I am staying with the steel rod for this build. This build is an early block that I converted to 4 bolt mains so it is the shorter cylinder length. So next question the 4.3 or the 4.5 crank and a 6.7 or 6.8 rod with the proper piston to address the piston sticking out the bottom of the bore. I hadn't heard of this glitch or is it not to be worried about? My 545 that my brother is using that I built quite a few years ago is still running fine and hasn't had any problems other than a rod bearing for some reason or other that I fixed by having the one journal ground and slapped it back together and that was several years ago. My good friend Kurt who builds FE's and others too turned me on to the little addition of adding an oil line front to the back and I did that after the rod bearing failure. Most say that it is unecessary but it is cheap and easy to do. Yesterday when I was at a dyno session with Kurt he brought along an article that was about Jon Kasse's boss nine build that made 834 hp. Guess what he was using the oil line to the rear on that one. Now we know he thinks "out of the box" as they say but its hard to second guess a guy that built that MEL that won the antique engine class this year at engine masters. I would add that the MEL was in my opinion a POS for making power as I put one (stock 383 312 hp rated) in a 57 tudor htp in 62 or 63 and it was a dog it signed off at around 4500 rpm but it did have more torque than the 292 it replaced but the acceleration just wasn't there.
» Pros and Cons
» E85 Pros and cons ?
» Cheap 460 thrasher build plan for bracket tbird
» Tunnel ram vs single carb.......pros and cons ......any help would be appreciated
» Piston Out of the Hole - Pros/Cons
