which head
which head Empty which head
Post  boker May 6th 2013, 10:40 pm
i am planning a mild 429/460 build . i have two sets of heads to choose from , 429 dove heads or a set of 72 police interceptor heads .both need about the same amount of work . which should i go with ??
boker
which head Empty Re: which head
Post  dfree383 May 7th 2013, 12:34 am
what are you doing with the motor? do you intend to put pistons in it?
Post  bbf-falcon May 7th 2013, 9:28 am
Give us some more info about your intent w/project,because these 2 heads have their own purpose. Very Happy Good luck
Post  boker May 7th 2013, 1:43 pm
i am planing a f-100 build . it will be a street/strip set up .just wanting general info on each head , we have built several pull trucks useing the dove -c head but i just recently got the chance at a set of 429 pi heads..
boker
Post  IDT-572 May 7th 2013, 2:14 pm
The PI heads will flow more than the Dove's and will make a nice set of street heads on pump gas with a flat top piston.
Post  rmcomprandy May 7th 2013, 7:09 pm
boker wrote:i am planning a mild 429/460 build . i have two sets of heads to choose from , 429 dove heads or a set of 72 police interceptor heads .both need about the same amount of work . which should i go with ??
Whichever set will provide the compression ratio you are looking for.
