Putting new rods in a engine?
Putting new rods in a engine? Empty Putting new rods in a engine?
Post  bigjohn2007 May 11th 2013, 10:40 am
At the point of putting rods in my first engine build.They are Scat 6.8 with arp 2000 screw.Says on box 70ft/lb w/arp moly [.0062'' stretch] not to exceed.I have a arp stretch gage now what is the procedure of installing the rods properly.
bigjohn2007
bigjohn2007
Putting new rods in a engine? Empty Re: Putting new rods in a engine?
Post  bosshoss May 11th 2013, 11:30 pm
When I do it I check the bolt first loose, zero the dial, torque to the regular setting then check bolt. If it has not reached full stretch I add 5 or 10 to the torque until it does.
dkp
bosshoss
bosshoss
Post  bigjohn2007 May 12th 2013, 11:20 am
I put rods in a vice with the bearing in and zero the dial with the bolt loose then torque 70ft/lb.Dail showed .0050 not .0062 so your saying i need to torque 5 or 10 more ft/lb until i reach .0062? thanks
bigjohn2007
bigjohn2007
Post  bosshoss May 13th 2013, 12:08 am
yep that's the way I do it except in the engine not in the vise.
bosshoss
bosshoss
Post  bigjohn2007 May 15th 2013, 11:21 pm
bosshoss wrote:yep that's the way I do it except in the engine not in the vise.
thanks for your help
bigjohn2007
bigjohn2007
Post  bigjohn2007 May 19th 2013, 10:52 am
So 70ftl/b just a starting point then the stretch gage is used to proper setting for each rod?
bigjohn2007
bigjohn2007
