Engine rods
10SHOTS
FORDMUD
Engine rods
Hava a customer wants to have us build motor for him.He was wondering aboutEagle rods and Doing the upgrade to the l-19 bolts.I have never used this type of stuff in my builds.Need info on if this stuff is any good.He wants a 466 ci with blue thunder heads about 12 to 1. Will they work ok.Please give imput. Thanks steve
Re: Engine rods
Whats it going to be used for? All natural or some sort of power adder? Why 12:1? Seems like an odd desired compression ratio.
FORDMUD- Posts : 290
RODS
He wants a bracket motor.Going to run a alchol carb and single plane intake.Won'spend the money for Crower rods or Corillo rods and thats all I use.Just testing the waters to see what low buck stuff will work good enough for about 700 hp and 6800 rpm and hold togather. Any imput I will be grateful. thanks steve
Re: Engine rods
I think you would have more than enough bolt with the 2000 series. Plus L19's are know to corrode. I guess that's the proper term. I'm running scat hbeams with the standard bolts at about your desired HP and rpm.
Re: Engine rods
dont run L19's in an alky deal, hell I got 2000's and Scat h beams in my turd.............more than enough IMO.
Re: Engine rods
FORDMUD wrote:I think you would have more than enough bolt with the 2000 series. Plus L19's are know to corrode. I guess that's the proper term. I'm running scat hbeams with the standard bolts at about your desired HP and rpm.
The correct condition for those bolts is that they are prone to "hydrogen imbrittlment" if they are not ALWAYS covered with some type of oil to keep them from the atmosphere.
I don't think EAGLE offers the 2000 bolt but, the L19's instead; (unless they have changed).
Preferably, I use the SCAT's with the 2000 bolts.
RODS
So are these better than the truck rods and the football head bolts?I do remember using them years ago? Thanks for your imput steve
eagle rod, 2000 bolts
Eagle offers the 2000 bolt in there rods now, got them in my motor
10SHOTS- Posts : 587
Re: Engine rods
STHAZLET wrote:He wants a bracket motor.Going to run a alchol carb and single plane intake.Won'spend the money for Crower rods or Corillo rods and thats all I use.Just testing the waters to see what low buck stuff will work good enough for about 700 hp and 6800 rpm and hold togather. Any imput I will be grateful. thanks steve
imo,Crower/Carillo rods are over kill in this build unless its in a high reving pulling truck engine. The Eagle rods and a Scat forged crank would serve him well.
Re: Engine rods
STHAZLET wrote:So are these better than the truck rods and the football head bolts?I do remember using them years ago? Thanks for your imput steve
The eagle rods work fine and are a definete upgrade over the stock rods, use 2000 bolts instead of the L19 stuff.
RODS
Thanks guys this is the kind of info I needed.The stuff I build for myself is a little more high tec than this.I didn't know on this type of build whhat would or wouldn't work well so I have gotten some good imput.Thanks.He wants me to use a roller cam he has,he lost the cam card.I am going to look it has a grind # and who made it.I will post later to see if any of you have heard of it. Again thanks a lot,you have me some good info steve
Re: Engine rods
Scat forged crank for a 466 . that something new ?bbf-falcon wrote:STHAZLET wrote:He wants a bracket motor.Going to run a alchol carb and single plane intake.Won'spend the money for Crower rods or Corillo rods and thats all I use.Just testing the waters to see what low buck stuff will work good enough for about 700 hp and 6800 rpm and hold togather. Any imput I will be grateful. thanks steve
DanH- Posts : 1081
Cam shaft
On the builds you guys use,How big a Camshaft do you use? Do you use flat tappet or roller?And what lift.I used to run a flat tappet around .750 lift.108 center line.They worked pretty good.Any Ideas?
Re: Engine rods
Need a lot more info..... Cam tech has come a long way in the last 20 years. I'd definetly look into a roller.
» 4.300 - 6.700 0r 6.800 rods for truck engine ??
» Putting new rods in a engine?
» Boat engine carb convert to drag engine
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
