Dive 460 block
Dive 460 block  Empty Dive 460 block
Post  boker May 17th 2013, 12:20 am
I am looking at buying a 72 model 460 , to build for my 64 f-100 prostreet. Project . I know the 72 heads suck , but what about the block rods crank etc ? What's the deck height on this block compared to others ? Are the valves in the d2ve heads the same as the d3ve ?
boker
Dive 460 block  Empty Re: Dive 460 block
Post  466cj May 17th 2013, 12:39 am
Block, rods, crank are all as good any other put in a regular passenger car. What you intend to do with it will dictate how much of all that is usable. Deck height should be ~10.322". Early blocks were ~10.300" - 10.310". If it is a performance build you will want to get the deck squared and the height set based on what pistons you use and what piston to head clearance you want anyway.
466cj
Post  boker May 17th 2013, 12:41 am
Thanks ,
boker
