supply line
supply line
i'm using a -4 supply line can I use it for a 200hp hit. the kit is a super power shot... I do have a set of cheater solenoids if this will work
quick 52- Posts : 612
Re: supply line
-4 will support that and more just fine.
Re: supply line
thanks would you know the largest jet a power shot nitrous solenoid will flowrichter69 wrote:-4 will support that and more just fine.
Re: supply line
no jet lol.
Re: supply line
so with the no jet what fuel jet is usedrichter69 wrote:no jet lol.
Re: supply line
here's the plan to max out a power shot noid or use a cheater to spray a 80 jet if possible... the combo is weak but it been working... stock bottom sft cam 258 258 615 615 a429 heads victor 950 proform 4000 stall 700r4 3.89 #3900 with driver MT DR in a 52 f1 truck
Re: supply line
I believe a super powershot noid has either a 076 or 080 oriface . Ill look at some notes when I get home. A friend used a 071 fuel with no jet.
» MSD 6AL, line lock, tranny dipsitck, carb fuel line
» What is the weak line in the drive line ?
» Good C6 Line Pressure at 1000 rpm? And more... Stacked shift, Line pressure not changing at different vac levels
» Supply Shed.
» Fuel supply Question
» Supply Shed.
