Fuel supply Question
If I use the bypass at the Fuel pump to the tank,can I block off the one at the regulator coming back to the tank. I just don't see the need for 2 bypass's. I just don't know if the BP reg's are designed to be blocked at the return.
Re: Fuel supply Question
if you do you will need a deadhead style regulator, the pump bypass is a high pressure deal.
Can I make my bypass reg. a dead head by plugging the return port
what reg do you have?
» Fuel question ?
» Fuel Question: Does any one mix PO for their 385?
» fuel pump question
» Fuel pressure question
» Question about fuel system
