IDENTIFY BLOCK
IDENTIFY BLOCK
Day Custom Engines, Garland, TX is currently rebuilding my 429. The only numbers they have been able to find on the block are "460" cast backwards on the front and rear of the casting plus the number "9Y118503". What does this number tell me? The heads have casting number C9VE-A which, I understand, are nothing special...probably cast in 1969.
Thanks,
ROADSTER
Thanks,
ROADSTER
ROADSTER- Posts : 11
Re: IDENTIFY BLOCK
Lem, Thanks for your reply. Is it typical to have only the VIN on the block?
Re: IDENTIFY BLOCK
It should have C8VE, C9VE or D0VE casting on the side of the block.
Is it very light that its Barely legible or is the block all rusty?
Re: IDENTIFY BLOCK
ROADSTER wrote:Lem, Thanks for your reply. Is it typical to have only the VIN on the block?
I do not understand the 'only' question.
"9' is the year......Y is the plant the car was built in .
Re: IDENTIFY BLOCK
The block was thoroughly cleaned inside & out removing all paint and rust. Any numbers should be visible especially, on the outside of the block. We could find no other numbers but what appears to be a VIN number. I have a book with all the 429/460 block ID numbers...this block has none of them. Since the heads are marked C9VE-A, I expected to find C8VE or C8VY-A or C9VY-A or C9VE-B cast in the side of the block near the freeze plugs. We found nothing. It does have push in freeze plugs which, as I understand, FORD used on standard 429/460 blocks.
Thanks for your response
Re: IDENTIFY BLOCK
Your number is from a 1969 ford built at the wixom plant.
gary o- Posts : 27
Re: IDENTIFY BLOCK
have ran the numbers off the crank and those heads are better than 72 and up there high compression heads 74 to 77 cc
74f100- Posts : 28
» Can anyone identify these heads? They are blue thunder thx
» Please help me identify this motor
» need to identify pistons!
» Help to Identify Studs 7/16 or 3/8
» Can anyone identify this BBF solid roller?
