Aluminum Blue Thunder heads
Are Aluminum Blue Thunder heads worth buying? Will they produce 800+ hp on a 557 setup?
FordMudBogger15- Posts : 60
Re: Aluminum Blue Thunder heads
helps to say what model BT head your asking aboutFordMudBogger15 wrote:Are Aluminum Blue Thunder heads worth buying? Will they produce 800+ hp on a 557 setup?
like saying you own a Ford . OK what model
DanH- Posts : 1081
I have a set on my 514..Blue Thunder "B" aluminum with the Chevy exhaust bolt pattern.
Fresh, 14 to 1, single 4" Flying Toilet on alky...it made 838 HP with a very small .650" roller.
After hundreds of runs, it still dynos at a little over 800.
We have a customer with a 557 with the same heads, single dominator on gas that makes a hair over 900 HP with a bigger cam.
I will soon put my Blue Thunder top end on the market..
Keith
Keith
So what would be the best cylinder head that Blue Thunder offers that would make the best horsepower results?
http://www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/bes-bbf-blue-thunder-thor-headsFordMudBogger15 wrote:So what would be the best cylinder head that Blue Thunder offers that would make the best horsepower results?
cool40 wrote:http://www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/bes-bbf-blue-thunder-thor-headsFordMudBogger15 wrote:So what would be the best cylinder head that Blue Thunder offers that would make the best horsepower results?
Don;t forget the cost of what needs to be under those....... a JY 429 out of a Tbird ain't going to cut it for those !
this was a hell of a deal... https://www.429-460.com/t17457-blue-thunder-aluminum-headsdfree383 wrote:cool40 wrote:http://www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/bes-bbf-blue-thunder-thor-headsFordMudBogger15 wrote:So what would be the best cylinder head that Blue Thunder offers that would make the best horsepower results?
The Blue Thunder Thor is the full-on race head they offer.
It requires lots of special prep, pistons, valve train intake and all.
They are currently not available.
HP range...1300-1400 HP N/A on gas and carbs.
The other Blue Thunders that I referred to have a normal "CJ" type intake port and raised exhaust port.
Keith
Keith
» Blue thunder heads
» Are these blue thunder heads?
» Blue Thunder Heads
» Blue Thunder Two-piece Cast Aluminum Intake with Valley Tray (Converterd to EFI)
» Where to get Blue Thunder "B" heads?
