Blue thunder heads
Maddmattmustangs
Blue thunder heads
what do as cast blue thunder heads flow?
part number chca-oc
part number chca-oc
Re: Blue thunder heads
ck this thread out ....scroll about halfway down ..lots of good info
https://www.429-460.com/proven-builds-f4/cylinder-head-info-gathered-by-djohagin-t122.htm
FWIW, I had a set of Blue Thunder "B" (BBC exhaust) heads
ported locally back in 2006 and got these results back:
Intake Lift Before & After Porting
.100 83 81
.200 150 163
.300 226 232
.400 288 294
.500 320 325
.600 347 354
.700 365 372
.800 377 387
.900 370 400
Exhaust Lift Before & After Porting
.100 73 68
.200 115 120
.300 152 166
.400 181 202
.500 218 243
.600 233 264
.700 249 281
.800 256 286
.900 262 297
.100 83 81
.200 150 163
.300 226 232
.400 288 294
.500 320 325
.600 347 354
.700 365 372
.800 377 387
.900 370 400
.100 73 68
.200 115 120
.300 152 166
.400 181 202
.500 218 243
.600 233 264
.700 249 281
.800 256 286
.900 262 297
thanks for the info guys.
the heads i found are BBC exhaust ports.
are they worth 1400?
blown473 wrote:Mine cost $1500 new
Most likely that was the price for a bare set of Blue Thunders a few years ago. Then you have to hone the guides and cut those square cornered seats and do a valve job. That's another $300+ dollars most anyplace, so we're at $1800 to $1850. Then add about $500 or more for the all the parts. Valves, seat cups, valvesprings, retainers, locks, seals, shims, rocker studs, and guideplates. That will put you at $2300+ for an assembled pair with steel retainers. The price will go up again with titanium retainers.
Charlie Evans
c.evans- BBF VENDOR SPONSOR
cost of blue thunder heads
Charlie is correct, thats a bare head price, then you buy good valves, springs, retainers, locks, and then your valve job, in which blue thunder uses a very hard seat requiring a special cutter....you get the idea, good heads cost money, so does a good machinist to put them together right, and if you need an expert like Mr Evans to port them for max performance, then you need some more $$$$
blown473- Posts : 376
blown473 wrote:Charlie is correct, thats a bare head price, then you buy good valves, springs, retainers, locks, and then your valve job, in which blue thunder uses a very hard seat requiring a special cutter....you get the idea, good heads cost money, so does a good machinist to put them together right, and if you need an expert like Mr Evans to port them for max performance, then you need some more $$$$
It's the old story, you get what you pay for. It's like an old farmer told me, if you want good oats you'll have to pay good money, if you want them after they have been through the horse, I can give you a lot better deal...
Nevs- BBF CONTRIBUTOR
» Blue Thunder Heads
» Are these blue thunder heads?
» Blue thunder Heads
» Where to get Blue Thunder "B" heads?
» Blue thunder B heads?
